17254 Discussions
Error (10822): couldn't implement registers for assignments on this clock edge
Hi people,
Can you please help me out with the following problem:
I try to increment a signal from the state machine at the rising edge of the clock but it gives me the error: Error (10822): HDL error at Deserializer.vhd(131): couldn't implement registers for assignments on this clock edge
Here is the code:
library ieee;use ieee.std_logic_1164.all; use ieee.numeric_std.all; -------------------------------------- entity Deserializer is port( reset, serialin, clk, enable : in std_logic; bustofft,sink_imag : out std_logic_vector(11 downto 0); led1, led2, clkadc,cs : out std_logic ); end entity; -------------------------------------- architecture implementation of Deserializer is --component flip_flop is --port ( -- clk, reset,enable : in std_logic; -- countink : in integer range 0 to 99; -- countoutk : out integer range 0 to 99 -- ); --end component; -- Signals & Variables -- signal cyclecounter : integer range 0 to 15:=0; signal done : std_logic; signal internalbus : std_logic_vector(11 downto 0); ------------------------------------------------------------------- -- state definitions and signals ---------------------------------- ------------------------------------------------------------------- type state is ( Idle, Startadc, Listen, Talk ); signal present_state, next_state: state; ---------------------------------------------------------------------- --PORTMAPS------------------------------------------------------------ ---------------------------------------------------------------------- begin ------------------------------------------------------------------ -- sequential part of the statemachine ---------------------------- ------------------------------------------------------------------- process(reset, clk, next_state) begin if (reset = '1') then present_state <= Idle; elsif (rising_edge(clk)) then present_state <= next_state; end if; end process; process(present_state,next_state, enable, cyclecounter,done) begin case present_state is when Idle => if enable ='1' then next_state <= Startadc; else next_state <=Idle; end if; when Startadc => if (cyclecounter >= 2) then next_state <= Listen; else next_state <=Startadc; end if; when Listen => if cyclecounter >= 14 then next_state <= Talk; else next_state <=Listen; end if; when Talk => if done = '1' then next_state <= Idle; else next_state <= Talk; end if; end case; end process; process(present_state,clk,cyclecounter,done) begin case present_state is when idle=> cs<='1'; done<='0'; cyclecounter<=0; when startadc=> cs<='0'; done<='0'; if (rising_edge(clk)) then cyclecounter<= cyclecounter+1; end if; when listen => cs<='0'; if(rising_edge(clk)) then cyclecounter <= cyclecounter + 1; internalbus(cyclecounter-3) <= serialin; else end if; when talk => cs<='0'; done<='1'; bustofft<=internalbus; end case; end process; end architecture;
i need verilog code of reducing noise using adaptive filters for implemntation on "fpga"...i hve a projct...need help plzzz...
