17246 Discussions
Error (12002): Port "X" does not exist in macrofunction "Y"
I added i2c_opencores IP to Qsys like I did before.
The scl and sda are exported as conduits.
However, now I get this message in Quartus (similar for sda):
Error (12002): Port "i2c_opencores_0_export_scl_pad_io" does not exist in macrofunction "q_sys_inst"
The error is caused by this line in the Qsys instantiation in the Verlog file:
.i2c_opencores_0_export_scl_pad_io (PMODA_IO[2]),
I checked:
- Qsys instantiation template: .i2c_opencores_0_export_scl_pad_io is there
- bsf-file: no i2c_opencores_0_export_scl_pad_io there, while it was in
a previous version.
Any clues?
Jos
I will answer my own question. Because I used a previous project
as basis for the project in which the error occurred I got two
Qsys output folders with different names. This confused Quartus,
apparently. Removing the oldest folder solved the problem.
