17267 Discussions
Error (209062): Flash Loader IP not loaded on device 0
I am trying to flash my pcie385n_a7 using "aocl flash hello_world_131_pcie385n_a7.aocx" The command never completes because of the following error(s):
Info: Command: quartus_pgm -c 1 flash.cdf
Info (213045): Using programming cable "USB-Blaster [2-1.5]"
Info (209060): Started Programmer operation at Tue Feb 18 16:08:03 2014
Error (209053): Unexpected error in JTAG server -- error code 5
Error (209040): Can't access JTAG chain
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Tue Feb 18 16:08:04 2014
Error: Quartus II 64-Bit Programmer was unsuccessful. 4 errors, 0 warnings
Error: Peak virtual memory: 1694 megabytes
Error: Processing ended: Tue Feb 18 16:08:04 2014
Error: Elapsed time: 00:00:07
Running "quartus_pgm -c USB-Blaster -a" gives this output:
Info: Command: quartus_pgm -c USB-Blaster -a
1) USB-Blaster [2-1.5]
Unable to read device chain (JTAG chain broken)
I have checked over the usb blaster connections and they seem to correctly connected.
Am I missing something or is JTAG chain actually broken?
I bungled connecting the break-out board to the FPGA. I have now done it properly and aocl flash works like a chram.
Hey what do you mean by break-out board?
Did you really have to setup the hardware again and stuff like that?
Greetings
Hi Kevinkit,
Have a look at the PDF attached to this thread http://www.alteraforum.com/forum/showthread.php?t=41749 That should help you identify the breakout board for the PCIe-385N.
G
Hi thank you for the information,
This may not be the problem because from another PC it works fine. I am intern at a resarch center where some other student works also on the FPGA , he has no problems - but I have.
So, any other ideas?
Or could it still be the break-out board but somehow this error only occurs me?
