17261 Discussions
Error: Assert failure at IIEstimation.cpp
I am having the following issue with Altera Opencl Compiler (aoc commad) Quartus 14.1 build 190:
compiler warning: aggressive compiler optimization: removing unnecessary storage to local memory
******* error: assert failure at iiestimation.cpp(1145) *******
push->m_dependents.size() == 1 failed
0 libllvm-3.0.so 0x00007f98a33f790f
1 libllvm-3.0.so 0x00007f98a33f9882
2 libpthread.so.0 0x00007f98a1acc130
3 libllvm-3.0.so 0x00007f98a2ba4706 acl::iiestimation::pushpopgraph::estimate_ii_simple() + 1190
4 libllvm-3.0.so 0x00007f98a2baff97 acl::iiestimation::rerunonfunction(llvm::function&) + 2215
5 libllvm-3.0.so 0x00007f98a2a9714e acl::optimizationreport::runonfunction(llvm::function&) + 1950
6 libllvm-3.0.so 0x00007f98a286724f llvm::fppassmanager::runonfunction(llvm::function&) + 527
7 libllvm-3.0.so 0x00007f98a28673b0 llvm::fppassmanager::runonmodule(llvm::module&) + 80
8 libllvm-3.0.so 0x00007f98a2866d71 llvm::mppassmanager::runonmodule(llvm::module&) + 577
9 libllvm-3.0.so 0x00007f98a2866f1b llvm::passmanagerimpl::run(llvm::module&) + 187
10 aocl-llc 0x000000000040bbc0 main + 5248
11 libc.so.6 0x00007f98a0cf2af5 __libc_start_main + 245
12 aocl-llc 0x0000000000409759
stack dump:
0. program arguments: /altera/14.1/hld/linux64/bin/aocl-llc -march=fpga -mattr=option3wrapper -fpga-const-cache=1 -board /altera/14.1/hld/board/sockit/sockit/board_spec.xml -profile -dbg-info-enabled fpgagetvariance.bc -o fpgagetvariance.v
1. running pass 'function pass manager' on module 'fpgagetvariance.bc'.
2. running pass 'optimization report.' on function '@getvariance'
I got this error when I increased the number of looop inside my kernel.
Any help is reaally appreciated.
Thx
