17251 Discussions
Error: Can't synthesize current design -- Top partition does not contain any logic
module testmyand;
reg a,b;
wire c;
initial
begin
a=0;
b=0;
# 5 a=1;
# 10 b=1;
end
myand m(a,b,c);
endmodule
module myand(a, b, c);
// Input Port(s)
input a,b;
// Output Port(s)
output c;
assign c=a&b;
// Additional Module Item(s)
endmodule
when i want to test the second module using the first module ,Error: Can't synthesize current design -- Top partition does not contain any logic
I don't know why?
--- Quote Start ---
module testmyand;
reg a,b;
wire c;
initial
begin
a=0;
b=0;
# 5 a=1;
# 10 b=1;
end
myand m(a,b,c);
endmodule
// Input Port(s)
input a,b;
// Output Port(s)
output c;
assign c=a&b;
endmodule
I don't know why?
--- Quote End ---
First of all you have no input and output ports in your toplevel specified. With no ports in place the Quartus synthesis engine could remove all your logic ( your and-gate). The initial statement and your# value are good for simulation, but could not be used for synthesis.
Try this :
module testmyand ( a,b,c);
input a,b;
output c;
myand m(a,b,c);
endmodule
// Input Port(s)
input a,b;
// Output Port(s)
output c;
assign c=a&b;
endmodule
