- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Just installed 10.1 Web Edition, compiled, and got this message.
Why? I thought Cyclones were fully supported in Web Edition? Quartus identifies itself as Version 10.1 Build 153 11/29/2010 SJ Web Edition with no Service Pack Installed.コピーされたリンク
3 返答(返信)
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
All Cyclones are. Quartus II 10.1 is just buggy. I can't get mine to compile. It just errors saying "Selected Feature of TimeQuest timing analyzer is not available with my current license." Too bad I uninstalled ver 8.1 because that was working FINE.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I just experienced a similar problem; Quartus had completed a couple of builds successfully, then, without shutting it down, it decided it couldn't find a licence (licence in use).
Re-start of Quartus didn't fix. Licence is permanent, so not expired. No-one else is using it. Couldn't see any obvious Quartus processes in Task Manager. Re-boot of PC fixed the problem, so I suspect Quartus got a little 'confused' about the state of its licence.- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
When I try to compile .bdf file in project I get messages :
"Error: Selected feature of TimeQuest Timing Analyzer is not available with your current license, or license does not exist" I use Quartus II Version 10.1 build 153 11/29/2010 SJ Web Edition Then I installed it on another PC and it works normal. The OS is the same. Difference only in RAM. Can I have this problem becouse I use only 512 RAM?
