I am getting this message "Error: Current module quartus_fit ended unexpectedly" when i run my design in quartus7.1SP1. I am stuck with this error and the same design was compiling a week back. the onlu difference is i have installed 30 day evalution quartus subscription license. Is this causing problem??? Thanks, BhupeshLink Copied
got it what was causing problem......
In compilation process settings, multi processor setting for parallel compilation was set to 4....i think this setting came from some other system......i changed it to 1 and it worked..... cheers, bhupesh
