17256 Discussions
Error: Device family Cyclone is not supported by Formal Verification tool Conformal L
Hi everyone,
I get a strange error when I try to compile a project which I KNOW used to compile just fine before. The source is coming out of a CD so there is no way I modified it by mistake.
Error: Physical sythesis tool PALAC is not supported by Formal Verification tool Conformal LEC.
How can I fix this?
http://www.cognitivekipple.com/store/palace.png
Info: ******************************************************************* Info: Running Quartus II Analysis & Synthesis Info: Version 8.1 Build 163 10/28/2008 SJ Web Edition Info: Processing started: Sun Dec 21 20:13:51 2008 Info: Command: quartus_map --read_settings_files=on --write_settings_files=off all_01 -c all_01 Info: Found 1 design units, including 1 entities, in source file all_01.bdf Info: Found entity 1: all_01 Info: Found 2 design units, including 1 entities, in source file HEX2DEC.vhd Info: Found design unit 1: HEX2DEC-arc Info: Found entity 1: HEX2DEC Info: Found 2 design units, including 1 entities, in source file CLOCK40.vhd Info: Found design unit 1: clock40-arc Info: Found entity 1: clock40 Info: Elaborating entity "all_01" for the top level hierarchy Warning: Using design file CLOCK_SPK.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project Info: Found design unit 1: clock_spk-arc Info: Found entity 1: clock_spk Info: Elaborating entity "CLOCK_SPK" for hierarchy "CLOCK_SPK:17" Info: Elaborating entity "clock40" for hierarchy "clock40:inst3" Warning: Using design file CYC_PLL.tdf, which is not specified as a design file for the current project, but contains definitions for 1 design units and 1 entities in project Info: Found entity 1: CYC_PLL Info: Elaborating entity "CYC_PLL" for hierarchy "CYC_PLL:inst" Info: Elaborating entity "altpll" for hierarchy "CYC_PLL:inst|altpll:altpll_component" Info: Elaborated megafunction instantiation "CYC_PLL:inst|altpll:altpll_component" Info: Instantiated megafunction "CYC_PLL:inst|altpll:altpll_component" with the following parameter: Info: Parameter "clk0_divide_by" = "5" Info: Parameter "clk0_duty_cycle" = "50" Info: Parameter "clk0_multiply_by" = "6" Info: Parameter "clk0_phase_shift" = "0" Info: Parameter "clk1_divide_by" = "1" Info: Parameter "clk1_duty_cycle" = "50" Info: Parameter "clk1_multiply_by" = "3" Info: Parameter "clk1_phase_shift" = "0" Info: Parameter "compensate_clock" = "CLK0" Info: Parameter "inclk0_input_frequency" = "50000" Info: Parameter "intended_device_family" = "Cyclone" Info: Parameter "lpm_type" = "altpll" Info: Parameter "operation_mode" = "NORMAL" Info: Parameter "pll_type" = "AUTO" Info: Parameter "width_clock" = "6" Info: Parameter "width_phasecounterselect" = "4" Warning: Using design file CLOCK2.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project Info: Found design unit 1: clock2-arc Info: Found entity 1: clock2 Info: Elaborating entity "CLOCK2" for hierarchy "CLOCK2:inst2" Warning: Using design file CLOCK2500.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project Info: Found design unit 1: clock2500-arc Info: Found entity 1: clock2500 Info: Elaborating entity "CLOCK2500" for hierarchy "CLOCK2500:14" Warning: Using design file clockall.gdf, which is not specified as a design file for the current project, but contains definitions for 1 design units and 1 entities in project Info: Found entity 1: clockall Info: Elaborating entity "clockall" for hierarchy "clockall:9" Warning: Using design file CLOCK150.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project Info: Found design unit 1: clock150-arc Info: Found entity 1: clock150 Info: Elaborating entity "CLOCK150" for hierarchy "clockall:9|CLOCK150:29" Warning: Using design file CLOCK16.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project Info: Found design unit 1: clock16-arc Info: Found entity 1: clock16 Info: Elaborating entity "CLOCK16" for hierarchy "clockall:9|CLOCK16:27" Warning: Using design file DEBUGLED.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project Info: Found design unit 1: debugled-arc Info: Found entity 1: debugled Info: Elaborating entity "DEBUGLED" for hierarchy "DEBUGLED:10" Info: Elaborating entity "HEX2DEC" for hierarchy "HEX2DEC:inst4" Warning: Using design file HHMMSS.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project Info: Found design unit 1: hhmmss-arc Info: Found entity 1: hhmmss Info: Elaborating entity "HHMMSS" for hierarchy "HHMMSS:11" Warning: Using design file LEDFLASH.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project Info: Found design unit 1: ledflash-arc Info: Found entity 1: ledflash Info: Elaborating entity "LEDFLASH" for hierarchy "LEDFLASH:12" Warning: Output pins are stuck at VCC or GND Warning (13410): Pin "FP_DATA_DIR" is stuck at GND Warning (13410): Pin "SEG" is stuck at GND Warning: Output port clk0 of PLL "CYC_PLL:inst|altpll:altpll_component|pll" feeds an output pin via global clocks -- jitter performance depends on switching rate of other design elements. Use PLL dedicated clock outputs to ensure jitter performance Warning: Design contains 5 input pin(s) that do not drive logic Warning (15610): No output dependent on input pin "KEY" Warning (15610): No output dependent on input pin "KEY" Warning (15610): No output dependent on input pin "KEY" Warning (15610): No output dependent on input pin "KEY" Warning (15610): No output dependent on input pin "KEY" Info: Implemented 721 device resources after synthesis - the final resource count might be different Info: Implemented 13 input pins Info: Implemented 30 output pins Info: Implemented 677 logic cells Info: Implemented 1 ClockLock PLLs Info: Quartus II Analysis & Synthesis was successful. 0 errors, 20 warnings Info: Peak virtual memory: 186 megabytes Info: Processing ended: Sun Dec 21 20:14:13 2008 Info: Elapsed time: 00:00:22 Info: Total CPU time (on all processors): 00:00:16
--- Quote Start ---
Hi everyone,
How can I fix this?
--- Quote End ---
did you change the Quartus version ? Something must be different ?
Nope,
No changes at all. Same code, made sure it is the same exact file. It came out of an old USB memory stick so I know it has not been modified.
Can someone provide at least a high level summary of what is the meaning of this error
B
--- Quote Start ---
Nope,
--- Quote End ---
In the EDA tools setting is the tool "Palace" for physcical synthesis choosen. To be hoenst I don't know this tool. The problem is now that for Formal verification you choose Conformal LEC, but Confromal does not support Palace.
Kind regards
GPK
