17254 Discussions
Error: Failed to refresh PTF file G:/ExerciseProgramfiles/NiosIILAB/kernal.ptf (-1)
Rencently i am using sopc builder to build a small sopc projcet (the following picture)
https://www.alteraforum.com/forum/attachment.php?attachmentid=6830
when finished an try to generate an error turned up as follws:
i'm using win7 + qii 11.0 + nios 11.0
Info: Finished elaborating module.
Executing: D:/altera/11.0/quartus//sopc_builder/bin/sopc_builder --classic --generate G:/ExerciseProgramfiles/NiosIILAB/kernal.ptf
Error: Couldn't run process D:/altera/11.0/quartus//sopc_builder/bin/sopc_builder --classic --generate G:/ExerciseProgramfiles/NiosIILAB/kernal.ptf successfully
this picture is the errors:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6829
I have problem like you, so you fix this problem yet?
Can you help me to fix this problem
Info: Finished elaborating PTF file.
Executing: C:/altera/91sp2/quartus//sopc_builder/bin/sopc_builder --classic --generate C:/altera/lab_Nios/lab_1/nios_system.ptf
Error: Couldn't run process C:/altera/91sp2/quartus//sopc_builder/bin/sopc_builder --classic --generate C:/altera/lab_Nios/lab_1/nios_system.ptf successfully
Error: System generation failed.
