17265 Discussions
Error appending bits to std_logic_vector
I'm trying to do a very simple multiply by shifting and some adds. Here are the arrays i am using.
type pixel_array is array(8 downto 0) of std_logic_vector(7 downto 0);
signal gaussianPixels : pixel_array; -- 3x3 array of pixels to be used for gaussian blur
type gaussian_partial_sum_array is array(2 downto 0) of std_logic_vector(15 downto 0);
signal gaussianPartialSum : gaussian_partial_sum_array;
I'm trying to multiply (3) by 2 and add it to (0) and (6). since they're all multiples of 2 im trying to just implement this with shifts as follows.
gaussianPartialSum(0) <= ((7 downto 0 => '0') & gaussianPixel(0)) + ((3 downto 0 => '0') & gaussianPixel(3)& (3 downto 0 => '0')) + ((7 downto 0 => '0') & gaussianPixel(6));
But when I compile this, quartus give me an error saying:
Error (10327): VHDL error at top.vhd(377): can't determine definition of operator ""+"" -- found 0 possible definitions
Am i doing something wrong? i found some code online that showed that this is the way to do this.
many thanks for your help!
You can't add (to) vectors. You have to cast to unsigned or integer and then back.
You cannot do arithmatic on the std_ logic vector type. You need to include the numeric std library and use the unsigned and signed types. You should probably declare your arrays using then to.
--- Quote Start ---
--- Quote End ---
Thanks! that did the trick.
