- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
i try to compile my project,but i found this error:
error: ddio node "niosii_cycloneii_2c35_standard_sopc:inst|ddr_sdram_0:the_ddr_sdram_0|ddr_sdram_0_auk_ddr_sdram:ddr_sdram_0_auk_ddr_sdram_inst|ddr_sdram_0_auk_ddr_datapath:ddr_io|ddr_sdram_0_auk_ddr_dqs_group:\g_datapath:0:g_ddr_io|altddio_bidir:dqs_io|ddio_bidir_50l:auto_generated|output_cell_l[0]" could not be constrained to a legal location). Can any one help me to solve this problem:confused::confused::confused:Link kopiert
1 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I'm not sure, but I guess it is because you set a PIN in a illegal Bank, for example if you set DDR_DQS[7:0] in bank 4 and that I/O need special features such 1v2 (1.2 voltage) and after you put another output signal (in same bank 4) witch requires 3v0, should be occur a BANK conflict .
I hope this tip help you. Best regards. -- Made in Floripa
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
