17255 Discussions
Error during CPLD gate-level sim
I am running gate-level sim of a design, written in Verilog for a MAX3000A CPLD and I am getting errors. Does anyone know what is going on? What issue is the error indicating? Attaching the ModelSim transcript.
Tony
ModelSim transcript:
# Loading instances from spisram_v.sdo
# Loading timing data from spisram_v.sdo
# ** Note: (vsim-3587) SDF Backannotation Successfully Completed.
# Time: 0 ps Iteration: 0 Region: /spisram_tb File: Z:/sram_clpd/altera/spisram_tb.v
# WARNING: No extended dataflow license exists
# add wave *
# view structure
# .main_pane.structure.interior.cs.body.struct
# view signals
# .main_pane.objects.interior.cs.body.tree
# run -all
# 0 << Starting the Simulation >>
# 0 addr=0000000000000000000, data=xxxxxxxx, ctrl=01, sclk=0, ss=1, mosi=0, miso=x
# 1 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=1, mosi=0, miso=z
# 20 << Single Write Test >>
# 20 << Slave Select >>
# 21 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z
# 22 << Driving byte: 07 >>
# 23 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=0, miso=z
# 25 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z
# 27 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=0, miso=z
# 29 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z
# 31 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=0, miso=z
# 33 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z
# 35 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=0, miso=z
# 37 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z
# 39 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=0, miso=z
# 41 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z
# 42 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=1, miso=z
# 43 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=1, miso=z
# 45 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=1, miso=z
# ** Error: C:/altera/11.0/modelsim_ase/win32aloem/../altera/verilog/src/max_atoms.v(2128): $setup( datain:44500 ps, posedge pclk[0] &&& reset:45200 ps, 1300 ps );
# Time: 45200 ps Iteration: 2 Instance: /spisram_tb/U1/\data0[5] /preg
# 47 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=1, miso=z
# 49 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=1, miso=z
# 51 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=1, miso=z
# 53 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=1, miso=z
Looks like an "unknown" error, because the error number and description text according to the specified ModelSim message format are both missing.
Unless it's a known issue (you should check): report to Altera support.
FvM,
Thanks for taking the time to respond. I think I was clocking the design too fast. When I reduced the clock rate in the test bench, the gate-level sim errors disappeared.
Tony
So it's apparently a regular timing violation assertion generated by the Altera libraries.
In my opinion, the message text is lacking some information.
