17268 Discussions
Error during Flash based system compilation
Hi there ,
I am about to design an external memory ( flash ) based system , here i give the Qsys design , but during quartus compilation i got these errors , attached text file
hope some help
thanks in advance :)
Two lines of the trace give me a clue but not how to solve it:
--- Quote Start ---
Warning (10230): Verilog HDL assignment warning at altera_merlin_width_adapter.sv(958): truncated value with size 24 to match size of target (8)
--- Quote End ---
and:
--- Quote Start ---
Error (10198): Verilog HDL error at altera_merlin_width_adapter.sv(433): part-select direction is opposite from prefix index direction
--- Quote End ---
Each of these suggest things may not be connected up as intended. How are you instantiating your qsys module? It looks like "off_chip_mem" is your top level Qsys entity - right? So, you're just throwing your generated Qsys output at Quartus - no higher level vhdl module...?
Cheers,
Alex
Hi a_x_h_75 !
Sorry for being late to reply , so much work since then , in any way you are right i didn't code a top level entity , i thought set as top level entity is enough :rolleyes: ,
I am working on it for the moment .
Just a question why set as top entity tool didn't work , i am working on Quartus 13.1 , and have added the .qip file and then right click set as top entity
thanks a lot , (thought that none would dare read the .txt error file , but you did "My respect !!")
