Hi everyone,
I'm working on a project in which I have to use DDR2 SDRAM. Therefore, I tried using the DDR2 SDRAM high performance controller via the Megawizard plugin manager. After finishing, however, when I try to compile the design, I immediately get the following error: Error: Tcl error: More than 1 positional argument specified: C:/Program, Files/Altera/ip/ddr2_high_perf/lib. Anyone knows how to solve this? Regards, TijmenLink Copied
I think because of space in your directory name.
Install altera software such that there is no any spaces in directory names. Regards, Hardik- Mark as New
Installed it again in another directory, and it works. Thanks! However, it seems pretty weird to me that this problem still exists while Program Files is a common directory to install new files.
Regards, Tijmen- Mark as New
Avoid to use space in directory name while using any altera tools.
--- Quote Start --- it seems pretty weird to me that this problem still exists --- Quote End --- Yes. Apparently, the processing is through Tcl command line calls. The Megawizard is basically an assembly of Java scripts, it should embed the file path with quotation marks, but it doesn't. File a support request!
