Error during compilation
Hello Friends,
I am compiling a project in Quartus 10.1SP1. The targeted chip is EP2AGX125DF25I3. It is giving me the following error -
"Error: There is no valid device available". I am using the web-edition of Quartus. Are there some limitations in this and is the error due to this? When I change the device it is compiling correctly with no errors (but with warnings).
Can anyone advice me?
Vinod.
--- Quote Start ---
Hello Friends,
Vinod.
--- Quote End ---
the web edition supports only Arria II GX FPGAs: EP2AGX45, EP2AGX65.
Have a look to : http://www.altera.com/literature/po/ss_quartussevswe.pdf
Kind regards
GPK
Thank u very much indeed.
I thought the web edition supports all devices but generates only a time-limited programming file. This is an eye opener :)
hi every one
i have a problem in compiling 4bit adder using vhdl in quartus 2 10.1 cyclone 2 ep2c35f672c6
Library ieee;
Use ieee.std_logic_1164.all;
Entity 4bitadder is -- it is showing error here
Port
I0,I1 : in STD_LOGIC_VECTOR(3 downto 0);
Cin : in STD_LOGIC;
S : out STD_LOGIC_VECTOR(3 downto 0);
Cout : out STD_LOGIC
End 4bitadder;
Architecture arch of 4bitadder is -- it is showing error h
Component fulladder
Port
A,B,Cin : in std_logic;
S,Cout : out std_logic
End component;
Signal Temp : STD_LOGIC_VECTOR(2 downto 0);
begin
FA1: fulladder port map
A => I0(0),
B => I1(0),
Cin => Cin,
S => S(0),
Cout => Temp(0)
FA2: fulladder port map
A => I0(1),
B => I1(1),
Cin => Temp(0),
S => S(1),
Cout => Temp(1)
FA3: Fulladder port map
A => I0(2),
B => I1(2),
Cin => Temp(1),
S => S(2),
Cout => Temp(2)
FA4: fulladder port map
A => I0(3),
B => I1(3),
Cin => Temp(2),
S => S(3),
Cout => Cout
End arch;
wheather i have to include 1 bit adder in this file or as an another file when using component instantiation please tell me that
my errors are
Error (10500): VHDL syntax error at 4bitadder.vhd(4) near text "4"; expecting an identifier
Error (10500): VHDL syntax error at 4bitadder.vhd(14) near text "4"; expecting an identifier
please help me as soon as possible.
VHDL identifiers can't start with a digit. Rename it to Adder4bit and you shouldn't have this error any more.
