Error in Modelsim-AE
When running simulation with Modelsim-AE I have this error:
** Fatal: (vsim-7) Failed to open VHDL file "memory.hex" in rb mode. No such file or directory. (errno = ENOENT)
But the file is indeed present in the same directory as the calling .vhd file.
Is this a frequent (and solved) issue?
Thank you.
Have you tried copying the memory.hex into the modelsim (mentor) directory?
The file was in the vhdl source files directory but it has to be in the project root directory. It's ok now.
