Error in case staement
I am trying to run a small code of VHDL on Quartus and it errors out saying
error (10321): VHDL error at PPC_PCI_SM.vhd(499): choice ""10H"" overlaps with a previous choic
error (10321): VHDL error at PPC_PCI_SM.vhd(499): choice ""00H"" overlaps with a previous choice
Which is basically a "case" error
I have attached the relavant code too ,but strangely precision( a mentor tool) passes it..
clocked_state : PROCESS ( ppc_clk_66m,rst_N)
variable wait_it_pci : natural range 0 to 5 ;
BEGIN
if (rst_N = '0') then
int_pci_dma_size <= SINGLE;
ppc_state <= PPC_IDLE;
wait_it_pci := 5 ;
ppc_read_brst <='0';
int_dma_access <= '0';
ta_read_N <= '1';
r_ta_read_N <= '1';
ta_write_N <= '1';
int_pci_busy <= '0';
int_eod <= '0';
int_aack_N <= '1';
ppc_req <= '0';
ppc_mtx_fifo_odd_wr <= '0';
ppc_mtx_fifo_even_wr <= '0';
ppc_mrx_fifo_odd_rd_1 <= '0';
ppc_mrx_fifo_even_rd_1 <= '0';
ppc_mrx_fifo_odd_rd_3 <= '0';
brst_counter <= "00000000";
int_ppc2pci_be <= (others => '0') ;
int_pci_address1_ppcclk <= (others =>'0');
ppc_pipe_stop_ppcclk <='0';
fifo_rst_a <= '0';
int_pci_error_ppcclk <= '0';
pci_error_ppcclk <='0';
elsif (ppc_clk_66m'EVENT AND ppc_clk_66m = '1') then
r_ta_read_N <= ta_read_N ;
if ( int_pci_error_ppcclk ='1') then
pci_error_ppcclk <='1';
end if ;
case ppc_state is
when PPC_IDLE=>
wait_it_pci := 5 ;
fifo_rst_a <= '0';
int_aack_N <='1';
ppc_pipe_stop if (ppc_start='1') then
case int_dma_size_mux is
-- pour ganer une clk
when "110" => int_pci_dma_size <= EIGHT;
brst_counter <= EIGHT;
when "011" => int_pci_dma_size <= SINGLE;
brst_counter <= SINGLE;
when "111" => int_pci_dma_size <= DOUBLE;
brst_counter <= DOUBLE;
when "100" | "101" | "001" | "000"|"10H" | "00H" => int_pci_dma_size <= dma_wcount1;
brst_counter <= dma_wcount1;
when others => int_pci_dma_size <= (others =>'0');
brst_counter <= (others =>'0');
end case;
ppc_state <= PPC_WAIT;
ppc_req<= '1';
int_pci_busy <= '1';
-- brst_counter <= int_pci_dma_size;
if (int_pci_cmd(0)='0') then
ppc_pipe_stop_ppcclk <='1';
I don't know, what's the type of int_dma_size_mux, I guess std_logic_vector. If so "00H" is an alias for "001" and "10H" for "101". The case constants are existing twice, simply a VHDL syntax error. The error is probably ignored by the Precision tool, tha't the whole story. Or is there a different meaning of the said constants?
Oops You are right ,Its a std_logic_vector...:)
It's legal VHDL but questionable for synthesis. You can use '1', '0', 'Z', and sometimes 'X' (but only on the right-hand side of an assignment) but I'd avoid H and L altogether. These are meta-values that don't have any utility for a digital logic synthesis tool. They typically bit-encoded std_ulogic, so you only get 1/0 and hence the aliasing you're seeing.
