17249 Discussions
Error in hello world program in NEEK board
I am getting error while building the hello world program in NEEK board. The following error will occur.
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: `TSE_MAC_IS_MULTICHANNEL_MAC' undeclared here (not in a function)
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: initializer element is not constant
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: (near initialization for `tse_mac_device[0].tse_multichannel_mac')
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: `TSE_MAC_NUMBER_OF_CHANNEL' undeclared here (not in a function)
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: (near initialization for `tse_mac_device[0].tse_num_of_channel')
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: `TSE_MAC_MDIO_SHARED' undeclared here (not in a function)
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: (near initialization for `tse_mac_device[0].tse_mdio_shared')
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: `TSE_MAC_NUMBER_OF_MAC_MDIO_SHARED' undeclared here (not in a function)
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: (near initialization for `tse_mac_device[0].tse_number_of_mac_mdio_shared')
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: `TSE_MAC_PCS' undeclared here (not in a function)
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: (near initialization for `tse_mac_device[0].tse_pcs_ena')
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: `TSE_MAC_PCS_SGMII' undeclared here (not in a function)
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: (near initialization for `tse_mac_device[0].tse_pcs_sgmii')
/cygdrive/c/altera/81/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse_system_info.c:22: error: (near initialization for `tse_mac_device[0]')
make[1]: *** [obj/altera_avalon_tse_system_info.o] Error 1
make: *** [system_project] Error 2
Build completed in 25.063 seconds
sam:)
I have the same problem. did you overcome this problem?
I also have the same problem, anyone know how to solve these errors?
I have the exact same problem. Has anybody figured out how to fix this. Thanks!
Is the your "cygdrive" correctly installed? Cause I try run the nios2 terminal and appears a error with the cygdrive.
I have similars errors no my project (DE2_NET) and I found this page right now:
http://www.altera.com/support/kdb/solutions/rd02122007_738.html
Maybe it can help us!!!
