17249 Discussions
Error : object used but not declared
I just want to create a signal_copie_req out std_logic :
entity test_connexions is
port(
signals ...
signal_copie_req : out_std_logic;
COMPONENT test_connexions
PORT(
signals ...
i_test_connexions : test_connexions
PORT MAP (
signals ...
signal_copie_req => signal_copie_req,
but I have this error that I don't understand :
Error (10482): VHDL error at top_fpga_opg_master.vhd(3158): object "signal_copie_req" is used but not declared
Error (10558): VHDL error at top_fpga_opg_master.vhd(3158): cannot associate formal port "signal_copie_req" of mode "out" with an expression
Does anyone knows how to solve this problem ?
signal_copie_req => signal_copie_req -- Error is here
--- Quote Start ---
port(
signals ...
--- Quote End ---
is this in your code, or is it "out std_logic;"
or
if there is the right one, then check the name of your entity, because the entity declares a component with its own name...
Or I don't understand what you are doing because it's only parts of you whole code.
Or you don't understand what a signal in VHDL means.
As taz said there should be a space between out and std_logic.
Also there should not be a , or ; at the end of a port or portmap.
This code is really confusing this way, just past you entity, component and portmap as a whole.
yep that was it "out_std_logic", sorry to give a piece of code and not the whole code like I wrote in my VHDL project.
Julien_92.
