17263 Discussions
Error pre-loading RAM on MAX10
I'm trying to pre-load a 2-port RAM IP on a MAX10 10M08SAE144C8GES. It should support pre-loading since it is an SA version.
When I get to assembling I get this error in Quartus Prime:
Error (14703): Invalid internal configuration mode for design with pre-initialized eram
Googling led me to try this:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd10302014_959.html
by adding
set_global_assignment -name ENABLE_ERAM_PRELOAD ON
to the qsf file.
But to no avail, as Quartus will not open the project with the line in the qsf file:
Error (125048): Error reading Quartus Prime Settings File C:/.../ADC_RAM.qsf, line 219
Info (125063): set_global_assignment -name ENABLE_ERAM_PRELOAD ON
Which configuration mode is selected for your project?
Under 'Assignments' -> 'Device', select 'Device and Pin Options'. Under the 'Configuration' tab ensure the 'Configuration mode' is set to a mode 'with Memory Initialization'.
Cheers,
Alex
That worked. Thanks!
