17263 Discussions
Error trying to generate encrypted FPGA configuration file
Hi Folks,
I am trying to encrypt the FPGA configuration file and I am getting an error. I am using Quartus II 14.0.
I referring to the document AN-556 titled: "Using the Design Security Features in Altera FPGAs" for the procedures to generate an encrypted FPGA configuration file and the key programming file.
Here is the error message:
[pavan@kt-hw1 run1]$ /home/tools/altera/14.0/quartus/bin/quartus_cpf --64bit -c -k ./output_files/keyfile:key1 output_files/zorya_top.sof output_files/zorya_top.rbf
Info: *******************************************************************
Info: Running Quartus II 64-Bit Convert_programming_file
Info: Version 14.0.0 Build 200 06/17/2014 SJ Full Version
Info: Copyright (C) 1991-2014 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, the Altera Quartus II License Agreement,
Info: the Altera MegaCore Function License Agreement, or other
Info: applicable license agreement, including, without limitation,
Info: that your use is for the sole purpose of programming logic
Info: devices manufactured by Altera and sold by Altera or its
Info: authorized distributors. Please refer to the applicable
Info: agreement for further details.
Info: Processing started: Tue Apr 7 09:03:13 2015
Info: Command: quartus_cpf --64bit -c -k ./output_files/keyfile:key1 output_files/zorya_top.sof output_files/zorya_top.rbf
Error: Quartus II 64-Bit Convert_programming_file was unsuccessful. 0 errors, 0 warnings
Error: Peak virtual memory: 361 megabytes
Error: Processing ended: Tue Apr 7 09:03:14 2015
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:02
Any ideas what might be wrong?
I noticed a line in the app note (AN-556) stating: "To enable the design security feature, you can obtain a license file from Altera Technical Support." Is this true? Do I need a special license to enable the Quartus II SW to generate encrypted configuration files in Quartus II 14.0?
If I need an additional license, what is the name of the license?
jp
If u are using subscription edition,the encryption license shud already bundled together with ur Quartus.try check ur license file..see if u can find 'FEATURE quartus_nonvolatile_encryption'.
