17254 Discussions
Error: (vcom-11) Could not find work.altera_syn_attributes.
When i am tring to simulate QuartusII project in modelsim-altera, the following error reported:
# ** Error: (vcom-11) Could not find work.altera_syn_attributes.
# ** Error: E:/Altera_Project/My_IP/FreqMeasure/FREQMeasure_WholeSystem.vhd(23): (vcom-1195) Cannot find expanded name: 'altera.altera_syn_attributes'.
# ** Error: E:/Altera_Project/My_IP/FreqMeasure/FREQMeasure_WholeSystem.vhd(23): Unknown record element "altera_syn_attributes".
# ** Error: E:/Altera_Project/My_IP/FreqMeasure/FREQMeasure_WholeSystem.vhd(25): VHDL Compiler exiting
# C:/altera/72/modelsim_ae/win32aloem/vcom failed.
I know that's because that I use library altera_syn_attributes in my VHDL file.
How can I direct modelsim-altera to find the library?
Thanks...
I think it is located here <QII instalation>/libraries/vhdl/altera/altera_syn_attributes.vhd. My understanding this attribute is meant for synthesis. You can remove or uncomment it during simulation or you can compile the altera_syn_attributes.vhd file into altera library. Hope it works.
The modelsim_ae normally ships with precompiled versions of the Altera-specific VHDL -- the altera_syn_attributes package was probably just omitted as an oversight. It contains declarations for all the Altera-supported attributes and should be compiled into the altera library. I'd file a support request. In the meantime, you can simply compile the package manually into the altera library, which I'm hoping you can do in modelsim_ae. GuruDog points out the file you need.
I primary use the full version of modelsim, so I'm used to compiling everything myself. Nice when things work automatically though. :)
Yes, it works.
Thanks both you, especially HDL_Guru, you always be so kind and patient :)
Thanks Altera Forum~~
I can get as much as I want in this forum. :)
