17254 Discussions
Error when specifying max work group size
Hi everyone,
I just find out that whenever I try to add max_work_group_size(X, Y, Z) attribute to a kernel I get the following error:
"error: attribute takes one argument"
Not even the example supplied by the programming guide compiles:
"aoc -v -c sum.claoc: Environment checks are completed successfully.
aoc: Selected target board de5net_a7
aoc: Running OpenCL parser....
c:/Users/RT/Desktop/sum.cl:1:16: error: attribute takes one argument
__attribute__((max_work_group_size(64,1,1)))
1 error generated.
Error: OpenCL parser FAILED.
Refer to sum/sum.log for details."
Where the ^ pointer points at letter 'm' of "max_work_group_size".
This is the source code from the example by the way:
"__attribute__((max_work_group_size(64,1,1)))
__kernel void sum (__global const float * restrict a,
__global const float * restrict b,
__global float * restrict answer)
size_t gid = get_global_id(0);
answer[gid] = a[gid] + b[gid];
This happens on both Linux and windows version 15 of AOCL, but "reqd_work_group_size(X, Y, Z)" works just fine.
I don't know if this is a bug of the compiler or am I missing something?
Thanks in advance!
the syntax of the attribute should be __attribute__((max_work_group_size(SIZE)),so just one argument as the compiler error suggested.
Cheers,
Sergio
Thanks Sergio! I discovered this sometime ago but I forgot to update the thread...
Cheers,
Ryan
