17252 Discussions
Error while trying to program EPCS flash in indirect SFL mode
(editing my previous thread for an update and save make the thread becomes blank, so I'm re-posting it as a new thread here)
On my new CoreEP4CE10 board, I'm able to upload designs successfully in FPGA
Ram using JTAG, but I'm unable to program EPCS Flash using JTAG Indirect SFL
mode.
Since this board doesn't have an AS connector, I have no other choice to
program using SFL, so I decided to try at command-line, but I got same
problem :
We can see below that SFLoader is actually succesfully loaded, but then the
JTAG hang and the EPCS is not detected.
Question : Are all boards using same FPGA are compatible with those SFL
"Factory default enhanced SFL image" provided ? Should I try to make my own
loader using SFL Megafunctions ?
Info: *******************************************************************
Info: Running Quartus II 64-Bit Programmer
Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Web Edition
Info: Copyright (C) 1991-2013 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, Altera MegaCore Function License
Info: Agreement, or other applicable license agreement, including,
Info: without limitation, that your use is for the sole purpose of
Info: programming logic devices manufactured by Altera and sold by
Info: Altera or its authorized distributors. Please refer to the
Info: applicable agreement for further details.
Info: Processing started: Wed Feb 19 12:11:02 2014
Info: Command: quartus_pgm -m JTAG -o pi;output_files/blinker.jic
Info (213045): Using programming cable "USB-Blaster(Altera) [1-1.3]"
Info (213011): Using programming file output_files/blinker.jic with checksum
0x1A5AF94D for device EP4CE10@1
Info (209060): Started Programmer operation at Wed Feb 19 12:11:03 2014
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x020F10DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Error (209037): JTAG Server can't access selected programming hardware
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Wed Feb 19 12:11:26 2014
Error: Quartus II 64-Bit Programmer was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 286 megabytes
Error: Processing ended: Wed Feb 19 12:11:26 2014
Error: Elapsed time: 00:00:24
Error: Total CPU time (on all processors): 00:00:00
UPDATE :
Following instruction of the Troubleshooting page
(http://www.altera.com/cgi-bin/ts.pl?fn=configuration&hi=2-8), I've manually
uploaded the SFL into the FPGA, then I've performed an antodetect again, and
I'm unable to see the EPCS, I'm only seeing the FPGA itself. Doing the same
at the command-line "jtagconfig" only shows the FPGA where I presume the
EPCS should also appear, but it doesn't ... I've check power supply
voltages, they look fine ... Is that mean my USB Blaster is defective (but
why I'm able to upload FPGA properly) ?
As you can see in this thread http://www.alteraforum.com/forum/showthread.php?t=44037 , I'm starting to think that it is related to the fact that some Blaster clones doesn't support SFL mode.
Please, if someone who is using one of those "sandpapered" Blaster clones can contradict me or confirm me, it would be apprieciated.
Is the EPCS device an Altera branded device or from a third party vendor? You may be seeing that error because the FLASH programmer doesn't recognise the ID of the configuration device fitted. There are plenty of vendors manufacturing serial FLASH parts but unless Quartus recognises the device ID it won't program it.
The way around this is to use the Nios FLASH programmer available from within Eclipse - having programmed your FPGA with a design containing a Nios core. You can set up the Nios FLASH programmer to work with third party devices successfully.
Is this you're own hardware? Have you ever had the FLASH device working? Is there a build fault?
Alex
Hi Alex,
Although I don't see Altera logo on the chip, it is a EPCS16N. But we never know when things come from China ... The board is a small dev board CoreEP4CE10 from WareShare.
I don't see any build fault, and originally, there was some test code in the EPCS, a small leds shift register, which as loading properly at power-up.
Unfortunately, this code probably been partially erased by all my trials...
BTW, is the EPCS device ID should shows up during a "jtagconfig -n" ? (I'm only seeing the FPGA and the SFL nodes.)
As mentionned in the other thread, http://www.alteraforum.com/forum/showthread.php?t=44037, I'm thinking that the issue is the USB Blaster clone, since I've about the same behavior with another board, an cheap chinese EP2C5, but which has an AS connector and works fine in that mode. Also, which also lead me to the same conclusion is the fact that each time I wish to reprogram the FPGA with JTAG mode, I've to disconnect the USB and reconnect it, otherwise, even "jtagconfig" won't see it. So, probably that in JTAG Indirect SFL mode, there is some king of reset occuring between to SFL loading and the EPCS programing, but the USB Clone is already hang in the second phase. Do you think my conclusion is right ?
So, I will have to wait the shipment of my latest order, an USB Blaster based on FTDI+CLPD, hoping it will solve the issue.
