17249 Discussions
Error with LMP counter component..
Hi all,
I have a design where I use the LPM_counter as a component "offline".
But, I get an error, which to me does not give any meaning... (See below text).
Does anyone have an idea of what I am doing wrong here...
Best Regards:
Martin C.
tools:
I am using Quartus 2 ver. 14.02.209. 64-bit.
Top_level vhd file is attached.
offline vhd file is attached.
The error points to line 236 of file: lpm_counter.tdf (also attached_changed extension for upload).
below is complete message read out from analysis:
--- Quote Start ---
Info: *******************************************************************
Info: Running Quartus II 64-Bit Analysis & Synthesis
Info: Version 14.0.2 Build 209 09/17/2014 SJ Web Edition
Info: Processing started: Tue Nov 04 14:11:56 2014
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off DMB512 -c DMB512
Info (20030): Parallel compilation is enabled and will use 4 of the 4 processors detected
Info (12021): Found 2 design units, including 1 entities, in source file fsm.vhd
Info (12022): Found design unit 1: FSM-Behavioral
Info (12023): Found entity 1: FSM
Info (12021): Found 2 design units, including 1 entities, in source file top_level.vhd
Info (12022): Found design unit 1: Top_level-Top_level_architecture
Info (12023): Found entity 1: Top_level
Info (12021): Found 1 design units, including 1 entities, in source file dmb512.bdf
Info (12023): Found entity 1: DMB512
Info (12021): Found 2 design units, including 1 entities, in source file filter.vhd
Info (12022): Found design unit 1: Filter-Behavioral
Info (12023): Found entity 1: Filter
Info (12021): Found 2 design units, including 1 entities, in source file clockcounter.vhd
Info (12022): Found design unit 1: ClockCounter-Behavioral
Info (12023): Found entity 1: ClockCounter
Info (12021): Found 2 design units, including 1 entities, in source file tb_clockcounter.vhd
Info (12022): Found design unit 1: tb_ClockCounter-behavior
Info (12023): Found entity 1: tb_ClockCounter
Info (12021): Found 2 design units, including 1 entities, in source file send_p.vhd
Info (12022): Found design unit 1: send_p-Behavioral
Info (12023): Found entity 1: send_p
Info (12021): Found 2 design units, including 1 entities, in source file offline.vhd
Info (12022): Found design unit 1: offline-SYN
Info (12023): Found entity 1: offline
Info (12127): Elaborating entity "DMB512" for the top level hierarchy
Info (12128): Elaborating entity "Top_level" for hierarchy "Top_level:inst"
Info (12128): Elaborating entity "ClockCounter" for hierarchy "Top_level:inst|ClockCounter:Clock4800"
Info (12128): Elaborating entity "ClockCounter" for hierarchy "Top_level:inst|ClockCounter:Clock1200"
Info (12128): Elaborating entity "ClockCounter" for hierarchy "Top_level:inst|ClockCounter:LED_dimmer"
Info (12128): Elaborating entity "Filter" for hierarchy "Top_level:inst|Filter:P1Filter"
Info (12128): Elaborating entity "FSM" for hierarchy "Top_level:inst|FSM:STATEMACHINE"
Info (12128): Elaborating entity "offline" for hierarchy "Top_level:inst|offline:offline_comp1"
Error (287127): Text Design File syntax error: Text Design File contains '(' where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected
Error (287127): Text Design File syntax error: Text Design File contains IF where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected
Error (287127): Text Design File syntax error: Text Design File contains a symbolic name where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected
Error (287127): Text Design File syntax error: Text Design File contains ELSE where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 6 errors, 0 warnings
Error: Peak virtual memory: 548 megabytes
Error: Processing ended: Tue Nov 04 14:11:59 2014
Error: Elapsed time: 00:00:03
Error: Total CPU time (on all processors): 00:00:02
--- Quote End ---
Doesn't your first line need "is" at the end of it?
component offline is
Hi ghogerheiden,
The syntax does not require "is" in declaration of the component.
(no difference with/without).
Most likely a trivial syntax error. But don't expect meaningful answers without posting a complete source file, or at least the source text up to the first error.
P.S.: I just noticed that the error message refers to AHDL code, e.g. lpm_counter.tdf or some of it's imported files. In this case, the problem might be an illegal or unexpected lpm_counter configuration. Please check which file and code line is marked in the error message. An post the lpm_counter instance files, e.g. offline.vhd.
Updated the post with vhd files....
Is there any reason why you have an ahdl lpm counter when you have a vhdl design?
--- Quote Start ---
--- Quote End ---
I use the LPM counter component which is part of Quartus II sw, megafunction.
Easy/quick way to get a counter, thats why :-)
Br Martin.
Yes - but when you generate the counter - you have the choice of which language to generate it in. Why did you chose AHDL, rather than VHDL?
--- Quote Start ---
--- Quote End ---
I have not specifically chosen it to be an AHDL LPM component. (can't see how to chose between the two).
Project settings are set to use VHDL IP settings.
Project settings -> IP settings -> "IP generation HDL preference:" VHDL.
You specify the language for the output entity when you generate the core. Not in the project settings.
The LPM_counter.tdf.txt you posted doesnt seem to be a megawizard file? where did you get it from? it looks like library code to me - that shouldnt be included in your project.
From the looks of it, offline is the component you generated.
--- Quote Start ---
--- Quote End ---
The file: LPM_counter.tdf.txt is not "included" in my project by me, it is where I am pointed, if I double click the error in the message window:
So yes, this looks like a library file, but why do I get an error which points here? (Could there be a fault in the implementation of the LPM counter?).
--- Quote Start ---
--- Quote End ---
Highly unlikely. The LPM counter is about 15-20 years old.
Is that file in the db directory? if it is, try deleting the DB directory and start compilation again.
--- Quote Start ---
--- Quote End ---
It points to file location:
C:\altera\14.0\quartus\libraries\megafunctions
It is not in the db folder....
The first error points to these code lines:
OPTIONS ALTERA_INTERNAL_OPTION = "suppress_da_rule_internal=a101;suppress_da_rule_internal=s102;suppress_da_rule_internal=s103"; ( clock : INPUT; clk_en : INPUT = VCC; -- clock Enable cnt_en : INPUT = VCC; -- count Enable updown : INPUT = VCC; -- VCC counts up, GND counts down aclr, aset, aconst, aload : INPUT = GND; sclr, sset, sconst, sload : INPUT = GND; data : INPUT = GND; -- used by aload and/or sload cin : INPUT = VCC; q : OUTPUT; -- counter output cout : OUTPUT; -- LPM specification calls for the following, but MAX+PLUS II only implements -- 16 eq outputs: -- eq : OUTPUT; -- eq : OUTPUT; -- Counter decode output )
just to test if other lpm components work, i have implementing a lpm compare component, this works fine, no errors.
