Hello Everyone,
I am trying to run a OpenCL Wordcount program on an Altera FPGA using Quartus Prime Pro 15.1.2 Edition, and while programming the FPGA using JTAG I am getting the following Exceptions: ExclusiveAccess -> Trying to Acquire lock ==> lockname = kernel.process.sync.file.Altera => TID = 124 ExclusiveAccess -> Success Acquiring lock ==> lockname = kernel.process.sync.file.Altera => TID = 124 ExclusiveAccess -> Released lock ==> lockname = kernel.process.sync.file.Altera => TID = 124 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! This is getting generated continuously !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ExclusiveAccess -> Exception: ==> sun.nio.ch.SharedFileLockTable.checkList(FileLockTable.java:255) => lockName = kernel.process.sync.file.Altera => TID = 123 ExclusiveAccess -> Exception: ==> sun.nio.ch.SharedFileLockTable.checkList(FileLockTable.java:255) => lockName = kernel.process.sync.file.Altera => TID = 123 ExclusiveAccess -> Exception: ==> sun.nio.ch.SharedFileLockTable.checkList(FileLockTable.java:255) => lockName = kernel.process.sync.file.Altera => TID = 123 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! This is getting generated continuously !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! After this the compiler hangs and program is not responding !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Does anyone have any idea why I might be getting this error? Note: The OpenCL code has been generated from Java Code using a Compiler Thanks in Advance, SaurabhLink Copied
