17256 Discussions
Export design partitons Problem
ANi
​quarus prime standard edition 中 Export design partitons 生成的post-sythesis 或者 post-fit 文件都是xxx.qxp        而quartus prime pro edition 中 Export design partitons 生成的sythesis 或者final 文件是xxx.qdb。        quarus prime standard edition 和quartus prime pro edition软件对于导出网表用于复用是否有办法支持??
KennyTan_Altera
Can you put the final question in English? I will try to answer it.
ANi
 The post-sythesis or post-fit files generated by the export design partiton  in Quartus  Stand Version is  xxx.qxp file, while the sythesis or final file generated by the Export design partitons in the Quartus Pro Version is xxx.qdb File 。   Is there any way for the quarus prime standard and the Pro Version
to support the reuse of exporting web tables?​
KennyTan_Altera
Nope, each of the qdb or qxp are using a different format. You can't reuse it on different type of Quartus (pro/std)
