17267 Discussions
Extract and save the state of a Cyclone V device using CLI
MilosNovotny
I need to automate the process of Examining a Cyclone V device and save the resulting .jic file. That's for the purpose of saving a device state in the case of a failed test.
After some experimentation and many error messages I arrived at this command:
quartus_pgm -c USB-Blaster -m JTAG -o ei;init_state.jic;5CGXFC5C7@1
This doesn't do anything (not even an error message). I essentially want to do the same thing as if I Examined the device from GUI, after which I have the option to save a .jic file representing the device state. Any suggestions what to try next?
More requests and details:
I'm also interested in automating the programming the device using a .jic file (to ensure reproducibility of tests). I tried this command:
quartus_pgm -c USB-Blaster -m JTAG -o "p;init_state.jic"
where init_state.jic is the state I got from Examining the device within GUI. When I do this, I get this error: Error (213021): Device index 4 must be less than device index of physical JTAG chain. Check board or choose legal device index.
I found a workaround for this last step: When I program the device from the GUI, I can save the result in a .cdf file  This file references the .jic file used. If I then run this command:
quartus_pgm -c USB-Blaster state_uploader.cdf
The device is succesfully programmed. Any pointers as to what I'm doing wrong with the more direct approach would be welcome.
Also, I noticed that when I last tried this, I was using a different device identificator(?). As when I now open the same device, I get 5CGXFC5F7 instead of 5CGXFC5C7 (the next to last letter changed, I don't know why)
P.S. sorry if I chose the wrong label, I'm new to this
MilosNovotny
I'm using Quartus 20.1.1
Fakhrul
Hi MilosNovotny,
Great to hear you found the solution! I'll now move this to community support, making it a helpful reference for others in the forum.
Fakhrul
