- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
i have this error what do i do?
Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3776
Stack Trace:
0x43282: DYGR_ROUTE_TIMING_INFO::get_timing_node + 0xd6c2
0x131b0: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0xaf0
0x12e3c: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0x77c
0x127ed: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0x12d
0x15b3a: DYGR_PLACE_INFO_BODY::set_transient_data_members + 0x5a
0x1afd1: DYGR_PLACE_INFO_BODY::load_data_from_pdb + 0x191
0x2829: DYGR_PLACE_INFO_BODY::load_data + 0x29
0x289e: DYGR_PLACE_INFO::load_data + 0x3e
0x2a31: DYGR_DIE_INFO_BODY::load_data + 0x131
0x1951d: MPP_ROOT::start + 0x5bd
0x6bba: Legacy_fitter_Init + 0x5b4a
0x1e0f: Legacy_fitter_Init + 0xd9f
0x2e68: Legacy_fitter_Init + 0x1df8
0xf8a6: TclInvokeStringCommand + 0xc6
0x112a8: TclEvalObjvInternal + 0x328
0x121b5: TclEvalEx + 0x8d5
0x12d48: TclEvalObjEx + 0x2d8
0x1abbd: Tcl_EvalObjCmd + 0xfd
0x56917: TclExecuteByteCode + 0xe47
0xa2376: TclObjInterpProcCore + 0x76
0x7c117: Tcl_FSEvalFileEx + 0x1d7
0x7a626: Tcl_EvalFile + 0x36
0xbd5f: qexe_ipc_progress_bar_name + 0xf3f
0x11498: qexe_get_command_line + 0x1068
0x147a5: qexe_run_tcl_option + 0x585
0x1dacd: qcu_run_tcl_option + 0xb8d
0x14dbd: qexe_process_cmdline_arguments + 0x54d
0x14f21: qexe_standard_main + 0xa1
0x4c78: msg_exe_fini + 0x58
0x53bc: msg_exe_fini + 0x79c
0x1584: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5f9f: msg_exe_main + 0x8f
0xf09bb: uaw_wcsrchr + 0xeaefb
0x87b9f: uaw_wcsrchr + 0x820df
0x1bb8b7: ZwWaitLowEventPair + 0x1ad167
End-trace
Quartus II 64-Bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition
Service Pack Installed: 1
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
First (and this goes out to anyone submitting reports like this) is provide as much info as you can about
your system setup and what you were doing. Without that info few if any constructive comments can
be given. The first questions will always be your system config/version, quartus version, and device.
So what version of OS are you using? Be specific.
Version of quartus you stated, so good there.
What device are you compiling for?
Without any other info my only suggestion would be to do an uninstall/reinstall of Quartus and device support and retry.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
You should also try to recapitulate how you got there. Did compilation work before and started to fail after a certain step? Besides possible corruption of Quartus installation or design database, it can be also an erroneous or at least unsupported code construct.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
i am running on parallels using MacBook m3 i had the version 13.1 now i gave installed the newest version but the new version doesn't have cydone II which my exercises use
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
"i am running on parallels using MacBook m3..."
"i have this error what do i do?"
I thought as much. I don't believe Intel/Altera officially supports their latest code running in emulation on Apple ARM Macs,
much less running legacy code.
I would suggest finding a real Windows 10 based X86 PC. I use it all the time with 13.0sp1 for CycloneII. Works fine.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Let me know if there is any update.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Yes, parallel in mac not recommended running those in native arm.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
