FIFO queue
hey everyone,
I was wondering how to write a FIFO queue code using verilog.
I am unable to start it even.
it will be great if someone can help me in this matter.
Cheers
Muzammil
The dispatcher IP core in this design has a on-chip memory based FIFO in it that you could look at: http://www.alterawiki.com/wiki/modular_sgdma
Typically you just instantiate the scfifo or dcfifo megacores in your design if you need a FIFO. That design above only creates a FIFO because it needed to have byte enables to qualify the data going into the FIFO.
