公告
17268 讨论
Fatal Error in Platform Designer
David32
新分销商 II
1,535 次查看
I have created a hierarchical QSYS design.
This loads into Platform Designer, saves and passes validation checks.
However, when running "generate HDL" I am getting two errors:
Error writing sopcinfo ...etc
and Error writing qip report ... etc
(see the attached screen shot).
This QSYS is part of a much larger design so I recreated it as a standalone project and the errors still occur. The test project archive is also attached.
Grateful for any help or clues.
David
标签 (1)
0 项奖励
9 回复数
SyafieqS
员工
1,511 次查看
Let me take a look at the design attached and get back to you.
0 项奖励
SyafieqS
员工
1,472 次查看
David,
I am able to reproduce the issue, I am further looking into this. Will let you know once there is any update
0 项奖励
SyafieqS
员工
1,425 次查看
I have forwarded this issue to developer for further investigation to root cause the issue and fix.
0 项奖励
SyafieqS
员工
1,375 次查看
I am pending reply from developer regarding this.
0 项奖励
SyafieqS
员工
1,344 次查看
May I know how urgent this issue is?
Does this total roadblock your developments?
The reason is there might be bit delay is reply as developer is working on high priority case.
If no, I would suggest to reopen or create new case for this for follow up in future.
Let me know
0 项奖励
David32
新分销商 II
1,336 次查看
Hi SyafieqS,
At present it is not blocking, but would very much appreciate an answer within 2 weeks.
David
0 项奖励
SyafieqS
员工
1,301 次查看
Hi David,
Meantime, have you tried on latest Quartus release?
We have lot of bug that might be able to fix this.
Let me know.
0 项奖励
SyafieqS
员工
1,301 次查看
I mean bug that had been fixed
0 项奖励
SyafieqS
员工
1,272 次查看
Hi David,
Thanks for letting me know. After checking with developer, seem 2 weeks is not possible. Thus, I suggest to follow up this after >2 weeks. You may reopen or create mentioning this forum as this is to avoid the forum from idling. This is valid bug as we can confirm this in recent build. I am working closely with developer. Might take sometimes for wa/fix.
0 项奖励
回复
