17264 Discussions
Fatal Error in Platform Designer
David32
New Contributor II
I have created a hierarchical QSYS design.
This loads into Platform Designer, saves and passes validation checks.
However, when running "generate HDL" I am getting two errors:
Error writing sopcinfo ...etc
and Error writing qip report ... etc
(see the attached screen shot).
This QSYS is part of a much larger design so I recreated it as a standalone project and the errors still occur. The test project archive is also attached.
Grateful for any help or clues.
David
SyafieqS
Let me take a look at the design attached and get back to you.
SyafieqS
David,
I am able to reproduce the issue, I am further looking into this. Will let you know once there is any update
SyafieqS
I have forwarded this issue to developer for further investigation to root cause the issue and fix.
SyafieqS
I am pending reply from developer regarding this.
SyafieqS
May I know how urgent this issue is?
Does this total roadblock your developments?
The reason is there might be bit delay is reply as developer is working on high priority case.
If no, I would suggest to reopen or create new case for this for follow up in future.
Let me know
David32
New Contributor II
Hi SyafieqS,
At present it is not blocking, but would very much appreciate an answer within 2 weeks.
David
SyafieqS
Hi David,
Meantime, have you tried on latest Quartus release?
We have lot of bug that might be able to fix this.
Let me know.
SyafieqS
I mean bug that had been fixed
SyafieqS
Hi David,
Thanks for letting me know. After checking with developer, seem 2 weeks is not possible. Thus, I suggest to follow up this after >2 weeks. You may reopen or create mentioning this forum as this is to avoid the forum from idling. This is valid bug as we can confirm this in recent build. I am working closely with developer. Might take sometimes for wa/fix.
