17250 Discussions
Fitter Runtime on Latch based
I am importing a latch based design into stratix IV.
(No, It is beyond my paygrade to change the RTL
or netlist to remodel latches)
I find that fitter time really goes up on latch based designs.
The latch is modeled as a self-looping LUT.
Any Fitter options that can make it go faster?
Thanks for any advice.
If latches are inferred(i.e. Quartus recognizes them as latches) then it will time them like a register. But if it's physically designed as a loop, it may not recognize it's a latch. If that's the case, your design is just a huige combinatorial block with tons of loops. I'm guessing timing analysis croaks on that, which is where your fit time is spent. Just a guess. But if you can't change anything, perhaps "set_scc_mode -size 1" would help TQ run faster. Just a guess though.
Unfortunately, the command is only available in
STA:
ERROR: Quartus II Tcl command "set_scc_mode" is only available for use in the following executable:
quartus_sta
while executing
"set_scc_mode -heuristic"
