17255 Discussions
Forcing Quartus to use Cyclone IV embedded multipliers
I really need to free up some LEs so it would really help if my LPM_MULT blocks could be implemented in the embedded multiplier blocks. How do I do that?
I've looked at the documentation and in Table 25 it suggests that setting DEDICATED_MULTIPLIER_CIRCUITRY to YES is the way forward, but where do I do that?
Hi Oliver,
If you open the LPM_MULT block in the megawizard there is an implementation option where you can select "use dedicated multiplier circuitry".
CoGH
Yes, I found that, but all the options are greyed out.
Have you selected Cyclone IV in the megawizard?
Otherwise you can edit the .vhd directly and set the DEDICATED_MULTIPLIER_CIRCUITRY parameter.
Yes, I've set the Cyclone IV in the megawizard.
I've looked in the .vhd file and it says
-- THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
This doesn't surprise me, and I guess I can ignore it.
When you suggest setting DEDICATED_MULTIPLIER_CIRCUITRY, what's the syntax and where in the file does it belong?
It should already be there if it is a valid setting.
I created an LPM_MULT for Cycline IV in Quartus 11.1 sp1 and that had the DEDICATED_MULTIPLIER_CIRCUITRY parameter in there but the implementation wasn't greyed either.
Could you please post up your VHDL? I'd like to try editing my file to see if that works.
Thanks in advance.
Here you are.
Thanks, that's very interesting. I'll see what happens.
Oliver, which device are you targeting? the CIVGX15 does not have hard multipliers
My device is an EP4CGX22
Editing the vhdl to add the hint didn't make any difference at all :(
Which version of Quartus are you using?
11.1 Web edition
I've learnt that Quartus does something different when you use an lpm_mult to square a number. It works for me when multipying by a constant!
