GPIO on Qsys
名誉分销商 II
2,188 次查看
I am using the Quartus web edition to program a DEO-Nano board. I intend to use the GPIO header of the board to send data to a DDS. I wanted to use Qsys to design it but I can't find the GPIO headers in the Library. Am I supposed to add a new component and if so, what details should I fill in the component type? I'm sorry if this is a trivial question, I am very new to Qartus (or FPGAs for that matter).
Thanks!
0 项奖励
3 回复数
名誉分销商 II
1,076 次查看
Run through these two example designs;
Post#2: de0_nano_basic.zip
http://www.alteraforum.com/forum/showthread.php?t=39765
Post#2: de0_nano_sdram.zip
http://www.alteraforum.com/forum/showthread.php?t=45927
This example contains a Qsys system and uses GPIO, so will have features similar to what you are looking for.
In your case, where you want to communicate with a DDS, you will need to determine what the DDS interface protocol is, eg., is it a serial interface like SPI, or is it a parallel interface. If you have a part number, I can look at the data sheet and comment on what you would need to do.
Cheers,
Dave
0 项奖励
名誉分销商 II
1,076 次查看
Dear Dave,
Thanks for the quick reply. I am using the AD9910 DDS and it has parallel interface. So to have my DDS output frequencies really fast, I want to transfer the data in parallel. This might be asking for a bit much, but do you happen to know any examples that I can look at to interface a DDS with an FPGA. Thanks!
0 项奖励
名誉分销商 II
1,076 次查看
--- Quote Start ---
--- Quote End ---
The AD9910 does not look that different from the AD9956, it just has a higher operating frequency. Read through the documentation on this page;
https://www.ovro.caltech.edu/~dwh/carma_board/
specifically the AD9956 test report.
Cheers,
Dave
0 项奖励
回复
