17255 Discussions
Gate level Simulation passes but design fails on target borad
I am implementing a filter (2nd order) in Quartus Stratix II device running at 500KHz.
I simulated the design using ModelSim.
My Target hardware consists of stratix II device.
Input stimulus is sine wave of desired frequency.
Inputs coefficients decide the cutoff frequency.
Expected result is attenuation of sine wave at cut-off freq.
Design works fine in RTL as well as Gate level simulation.
1)
However, when programmed on target hardware, it fails completly and has output has no attenuation at lower frequencies (100Hz) and wrong beaviour at higher frequencies.
2)
I see that fast/slow model results in timing analyses show failures linked to my design. It indicated a different (40MHz) clock domain in the from/to section of the report. 40MHz is used for other sections and I don't use 40 Mhz for this piece of design.
Please suggest me how to go ahead from gate level simulation to on board running. I am kind of stuck, unable to proceed further.
Is there any settings that i need to check.
Thanks in advance.
VVP
Ok, thanks. happy easter and nice week-end. See u on tuesday.
You may look at the other issue, the timing. If your clock is 40MHz instead of actual clock ? then you need to enter/check timing settings in an sdc file.
I retried the figures for 100Hz filter. It looks my version of matlab gets this filter wrong. I still get the same results as before but I suspect it is the tool as I get inconsistent results between fvtool and freqz.
I would rather assume your friend's figures are correct since they look not that far from 200Hz filter...
Okay, For the timing issue:
Type : Slow Model Clock Setup:
Slack : -7.425 ns
Required Time : 40.00 MHz ( period = 25.000 ns )
Actual Time : 30.84 MHz ( period = 32.425 ns )
To : "...output path to output of the filter"
From Clock : path to 40MHZ clock from PLL
To Clock : path to 40MHZ clock from PLL
Failed Paths: 7874
40MHZ is input clock to a different module to generate 500 KHZ enable or ready signal. I use this ready or enable signal which is 500KHZ as clock for my filter. i dont use 40MHZ directly even once.
I added this path in assignment editor, with assignment name "clock enable multicycle" and a value = 2. But error is still present.
Perhaps, i should have assigned "Multicycle" and a value of 2.
I am compiling the project and will update you soon.
Please suggest, how to proceed.
I believe you should not use the enable as clock since it is gated clock and needs extra care. You can use the 40MHz to clock your registers then use that enable as clock enable. 40MHz is no problem to achieve.
Ok, i will try to do that. Do u think SLOW MODEL clock setup failure is due to this gated clock? And the filter failing on board as wel?
(The filter works fine in gate level simulation).
Please advice.
I tried with this assignment - "Multicycle" and a value of 2.
But the error is still there?
Pls advice.
To change clocking to clock 40MHz and clock enable you need to add to every clock edge assignment:
if (rising_edge(clk40mhz) then
if clken = '1' then -- your 100KHz rate
...etc
You must make sure timing is right before we blame the filtering itself.
I don't think you will need multicycle as 40MHz is too slow anyway
Thanks, I did as suggested and i still get the same SLOW model error. Please advice.
At 40Mhz, slow model error is still present.
I changed it to 20Mhz (for testing) and slow model error is gone.
However, the filter response didn't change. It still fails on board.
Please advice.
I am a bit surprised that 40MHz fails speed. There must be something unusual in your clocking scheme.
With regard 20MHz, remember it will affect your frequency point. If you are reading your sine input from LUT then all frequencies will go by half if sampled at 20MHz (unless your clken rate of 100 KHz is maintained).
I am giving a fixed sine wave of say 100 Hz. Expecting that it gets attenuated to 10% if coefficients corresponding to 100Hz are provided. CLock can be 20 Mhz (for testing) or 40 Mhz (desired) but with fixed clock_enable, which toggles at 500Khz rate.
However, on board it still does not give better results.
Please advice.
After looking back at some of the figures in this post, it seems I assumed sampling freq was 100K but actually you are saying it is 500KHz. Thus the two filters notch point must be moved 5 time higher (100Hz => 500Hz...etc).
So obviously both my analysis and your friend's point to same response but is in conflict with your expectations of actual frequency. Anyway, it is a not problem, all you need is look at the frequency point that corresponds to 5 times our posted figures.
The rule is simple: freq out = normalised freq * sampling freq/2.
normalised freq is 1.0 at half sampling freq.(in matlab functions)
A good indicator that your filter is wrong is if output is weird provided input freq is a regular sine.
i was away for couple of days due to personal reasons.
Agree to your point.
I tried something different now.
I reduced the sampling freq,Fs=125 KHz & then to 31.25 KHz for testing.
It works (on board) for Fc=100Hz also and the output waveform looks good.
But when I change the FS=500KHz, it does not work.
I don't have timing issues (as of now as i changed the clock to 20mhz as i reported to you earlier for sake of testing and to pin-point the issue).
please advice.
VVP
I hope you realise that changing Fs for a given filter will change the response proportionally.
If your filter is fixed for a response at Fs of 500Ksps to produce a notch at 100Hz, then that notch point will move to 100 *125/500 = 25Hz if Fs is made 125Ksps.
How do you know your input is at a given freq. If you generate from LUT then the freq will depend on Fs at LUT
Agreed to ur point.
I now, can generate freq from signal generator in the board set up.
In this case I have control over the freq of the input signal.
I then can give different Fc for a fixed Fs=125khz or 31.25khz of 500khz.
This is the way i checked the response.
