Generate SEU FIT Report
Alberto_G
Hello everyone,
I am having problems to generate the SEU FIT Report, I am using a Cyclone V family FPGA and from what I have seen it is necessary to use Quartus Prime Standard to be able to generate this report for this type of boards.
That is why I have acquired a license to use this version of Quartus and generate the report, then I followed the steps indicated in this post:
https://www.intel.com/content/www/us/en/docs/programmable/683869/current/enabling-the-projected-seu-fit-by-component.html
However, after writing the assignments in the .qsf and compiling the design it does not generate any type of report.
The highlighted line in the attached image indicates that a SEU license must be installed, does it refer to the Quartus Prime Standard license or is it another one?
Farabi
Yes, you need a license to generate SEU FIT report.
regards,
Farabi
Farabi
regards,
Farabi
Anri
Hi Farabi,
What is the part number for the license for SEU FIT report?
I have SW-ONE-QUARTUS license that was purchased via the distributor SHI.
Is SHI still your authorized distributor for North America?
Can I get a quote to purchase the required  license to run an SEU FIT report on a CPLD design targeting the 10M02SCE144A7G device?
Thank you!
Farabi
Hello Anri,
You need to request the license trough your distributor. Distributor will file IPS to Altera to request the license on your behalf.
regards,
Farabi
Farabi
Hello, additional information - you need Quartus Std or Pro to enable the SEU FIT report.
Hope this helps.
regards,
Farabi
