17260 Discussions
Generic component inside generic component
Hello.I am designing a vhdl code that has a generic size setting a bunch of operations.I cannot synthetize it with quartus (Error (10346): VHDL error at mac.vhd(7): formal port or parameter "width" must have actual or default value), but I am able to compile with modelsim.My question is, can I put a generic component inside another? If dont, how should I proceed?
entity mac is
generic
width : integer); -- QUARTUS POINTS HERE
port
clk : instd_logic
rst : instd_logic
a_i : instd_logic_vector(width-1downto0);
b_i : instd_logic_vector(width-1downto0);
acc : instd_logic_vector(2*width-1downto0);
out_o : outstd_logic_vector(2*width-1downto0
end mac;
architecture bhv of mac is
component mul
generic
W_g : integer);
port
clk : instd_logic
rst : instd_logic
a_i : instd_logic_vector(W_g-1downto0);
b_i : instd_logic_vector(W_g-1downto0);
outm_o : outstd_logic_vector(2*W_g-1downto0
endcomponent
component soma
generic
W_gs : integer);
port
clk : instd_logic
rst : instd_logic
outm_o : instd_logic_vector(2*W_gs-1downto0);
acc : instd_logic_vector(2*W_gs-1downto0);
outs_o : outstd_logic_vector(2*W_gs-1downto0
endcomponent;
You can put generics anywhere you like. The error is due to the fact you did not assign a value anywhere. Modelsim would have produced the same error had you tried to elaborate the design.
You can set generics using Quartus and Modelsim commands, however, you can also set a default value in your design, eg,
generic ( width : integer := 8 );
The width generic can then be overridden in Modelsim using vsim option -gwidth=16, and in Quartus via the set_parameter Tcl command (or using the GUI).
Cheers,
Dave
Value of width is provided by another entity.
I found what was wrong. I didnt knew i have to set the top level entity.
But thanks =D
--- Quote Start ---
--- Quote End ---
Right, but the error was because the component MAC did not have a value set.
--- Quote Start ---
I didn't knew i have to set the top level entity.
--- Quote End ---
Ah, I see, you accidentally had MAC as the top-level component.
I have got into the habit of putting default values in the entity/architecture file so that I can run a synthesis check, and then deleting them on the component definition in a package, so that I don't forget to put the generics on the component when I instantiate it.
Cheers,
Dave
No, the error was because the component MAC get its value from another entity, a top-level one.
Thanks for the hint
--- Quote Start ---
--- Quote End ---
Ok, you didn't put the generic map on the component when you instantiated it.
It sounds like you've got things sorted out now.
Note that if you have a generic (or a port) that would normally take on a specific value, then in your component definition, you can supply a value, and then that value will be used if you do not list that generic (or port) in the generic map.
Cheers,
Dave
