17265 Discussions
Generic parameter with variable size
Hi all
My design requires a parameter defined at compilation time that can range from 1 to 128 bytes. It isn't possible to create a generic based on another generic like this:
generic (
es_size : natural range 1 to 128 := 2;
es_info : bidim_array_t(es_size-1 downto 0) := (x"00",x"00"));
Where bidim_array_t is defined inside a package:
type bidim_array_t is array(natural range <>) of std_logic_vector(7 downto 0);
With this code Quartus reports the following error:
***generic "es_size" cannot be used in its own interface list***
Removing the es_size and fixating the size of es_info to 128 could be one solution but I would like to know if there is anything more elegant to do in this case.
Thank you
Best regards
Thiago
--- Quote Start ---
Hi all
generic (
Thank you
Best regards
Thiago
--- Quote End ---
I think generic should be a constant so that compiler knows what to do.
Your second declaration of bidim_array should be an input
