Hello Gurus,
I've a master clock that feeds different modules (say A,B,C). How to know the individual max frequency for each of the modules? Suppose the critical path is in module B and I know I won't be enabling it, then theoritically I can input Clk to the max supported by A or C. But TimeQuest will report FMax only for the top level clocks. Thanks, GopalLink Copied
If you know for sure you are not enabling B, you can simple cut it by adding a false path from B* to B*. look for set_false_path in the help or google "set_false_path TimeQuest". But if you don't want to remove B from the analysis, you can use report_timing -from A* -to A* to check the timing for A. Of course, I am assuming you have a target period defined on the clock, so this will show you the slack for paths within A. Hope this helps. DK- Mark as New
--- Quote Start --- Hi, If you know for sure you are not enabling B, you can simple cut it by adding a false path from B* to B*. look for set_false_path in the help or google "set_false_path TimeQuest". But if you don't want to remove B from the analysis, you can use report_timing -from A* -to A* to check the timing for A. Of course, I am assuming you have a target period defined on the clock, so this will show you the slack for paths within A. Hope this helps. DK --- Quote End --- Thanks, this is exactly what I was looking for.
