17254 Discussions
Get stuck at Analysis & Synthesis
Hello all,
I'm new with hardware description language.
I'm current design a TEA(Tiny Encryption Algorithm) using VHDL. I've finish the code, but it get stuck at Analysis & Synthesis, it just keep Analysis & Synthesis and never give any further information
Here is the code
LIBRARY ieee; USE ieee.std_logic_1164.all; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity TEA is port( encrypt : in bit; v0 : in bit_vector(63 downto 0); v1 : in bit_vector(63 downto 0); k0 : in std_logic_vector(63 downto 0); k1 : in std_logic_vector(63 downto 0); k2 : in std_logic_vector(63 downto 0); k3 : in std_logic_vector(63 downto 0); out0 : out bit_vector(63 downto 0); out1 : out bit_vector(63 downto 0) ); end TEA; ARCHITECTURE struct OF TEA IS BEGIN process(encrypt,v0,v1,k0,k1,k2,k3) constant delta : integer := 2654435769; variable m0 : std_logic_vector(63 downto 0) := to_stdlogicvector(v0); variable m1 : std_logic_vector(63 downto 0) := to_stdlogicvector(v1); variable sum : integer := 0; variable temp0 : integer := 0; variable temp1 : integer := 0; begin temp0 := conv_integer(m0); temp1 := conv_integer(m1); if encrypt = '1' then en: for i in 0 to 63 loop sum := (sum + delta); temp0 := temp0 + CONV_INTEGER( TO_STDLOGICVECTOR( to_bitvector(TO_STDLOGICVECTOR(to_bitvector(m1) sll 4) + k0) xor to_bitvector(conv_std_logic_vector((temp1 + sum),64)) xor to_bitvector(TO_STDLOGICVECTOR(to_bitvector(m1) srl 5) + k1) ) ); m0 := conv_std_logic_vector(temp0,64); temp1 := temp1 + CONV_INTEGER( TO_STDLOGICVECTOR( to_bitvector(TO_STDLOGICVECTOR(to_bitvector(m0) sll 4) + k2) xor to_bitvector(conv_std_logic_vector((temp0 + sum),64)) xor to_bitvector(TO_STDLOGICVECTOR(to_bitvector(m0) srl 5) + k3) ) ); m1 := conv_std_logic_vector(temp1,64); end loop en; else sum := conv_integer(TO_STDLOGICVECTOR(to_bitvector(conv_std_logic_vector(delta,64)) sll 5)); de: for i in 0 to 63 loop temp1 := temp1 - CONV_INTEGER( TO_STDLOGICVECTOR( to_bitvector(TO_STDLOGICVECTOR(to_bitvector(m0) sll 4) + k2) xor to_bitvector(conv_std_logic_vector((temp0 + sum),64)) xor to_bitvector(TO_STDLOGICVECTOR(to_bitvector(m0) srl 5) + k3) ) ); m1 := conv_std_logic_vector(temp1,64); temp0 := temp0 - CONV_INTEGER( TO_STDLOGICVECTOR( to_bitvector(TO_STDLOGICVECTOR(to_bitvector(m1) sll 4) + k0) xor to_bitvector(conv_std_logic_vector((temp1 + sum),64)) xor to_bitvector(TO_STDLOGICVECTOR(to_bitvector(m1) srl 5) + k1) ) ); m0 := conv_std_logic_vector(temp0,64); sum := (sum - delta); end loop de; end if; out0 <= to_bitvector(CONV_STD_LOGIC_VECTOR(temp0,64)); out1 <= to_bitvector(CONV_STD_LOGIC_VECTOR(temp1,64)); end process; END struct;
It didn't give any error or warning when run the Analysis & Synthesis.
many thanks
