Glitchs on a counter
Colaborador Distinguido II
1.715 Vistas
Hi everybody
I m facing a problem with quartus II and modelsim-altera.
Here is my VHDL code :
library ieee ;use ieee.std_logic_1164.all; use IEEE.numeric_std.all; --use ieee.std_logic_unsigned.all; use work.all; --------------------------------------------- entity AD7960_Ctrl is port( m_clk_i: in std_logic; --100MHz clock for timing reset_n_i: in std_logic; --reset signal active low clk_o: out std_logic --clock out ); end AD7960_Ctrl; ---------------------------------------------- architecture behavioral of AD7960_Ctrl is constant ADC_CYC_CNT : std_logic_vector(4 downto 0) := "10011" ; signal adc_tcyc_cnt: std_logic_vector(4 downto 0); begin clk_o<= '1' when adc_tcyc_cnt = "00010" else '0' ; process (m_clk_i,reset_n_i,adc_tcyc_cnt) begin if (reset_n_i = '0') then adc_tcyc_cnt <= ADC_CYC_CNT; elsif (m_clk_i='1' and m_clk_i'Event)then if adc_tcyc_cnt /= "00000" then adc_tcyc_cnt <= std_logic_vector(unsigned(adc_tcyc_cnt) - 1) ; else adc_tcyc_cnt <= ADC_CYC_CNT; end if ; end if ; end process; end behavioral;
And here my test bench:
-- testbench for counter_3bit -- Load Altera libraries for this chip LIBRARY IEEE; LIBRARY MAXII; USE IEEE.STD_LOGIC_1164.ALL; USE MAXII.MAXII_COMPONENTS.ALL; entity ad7960_ctrl_tb is end ad7960_ctrl_tb; architecture testbench1 of ad7960_ctrl_tb is signal m_clk_i: std_logic := '0'; --100MHz clock for timing signal reset_n_i: std_logic:= '0'; --reset signal active low signal clk_o: std_logic:= '0'; --clock out constant clk_period_100 : time := 10ns; begin -- dut = device under test (same name as top project from Quartus) dut : entity work.ad7960_ctrl -- Map the ports from the dut to this testbench port map ( m_clk_i=> m_clk_i , reset_n_i=> reset_n_i , clk_o=> clk_o ); -- Clock process definitions( clock with 50% duty cycle is generated here. MAIN_CLK_process :process begin m_clk_i<= not m_clk_i; wait for clk_period_100/2; end process; stim_proc: process begin wait for 13ns; reset_n_i <='1'; wait; end process; end ;
Here is the output waveforms:
http://www.alteraforum.com/forum/attachment.php?attachmentid=13105&stc=1
As you can see a have kind of glitchs on the output signal when my counter adc_tcyc_cnt goes from 0 to 19.
Critical warning in quartus are just :
Critical Warning: The following clock transfers have no clock uncertainty assignment. For more accurate results, apply clock uncertainty assignments or use the derive_clock_uncertainty command.
Critical Warning: From m_clk_i (Rise) to m_clk_i (Rise) (setup and hold)
and warning are just :
Warning: Feature LogicLock is not available with your current license
Warning: Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details
I if a change :
by (for exemple)
constant ADC_CYC_CNT : std_logic_vector(4 downto 0) := "10100" ;
there is no problem.
I would apreciate any help
thanks.
0 kudos
2 Respuestas
979 Vistas
I assume this is a post place and route simulation? These glitches occur because the clk_o signal is combinatorial.
Not all bits of the counter change at exactly the same time. So on the clock cycle with the glitch you momentarily get the value to match to output a 1 as the counter transitions back to 0.
To prevent these glitches you should register the clk_o output.
On a side note, why do you have an output called clk? Generating clicks on logic is not good practice and actually this doesn't look like a clock at all, more like a clock enable ( which is what you should generate).
979 Vistas
Here are a few tricks from an old timer: synchronous enabled design. It solves so many problems...
https://www.dropbox.com/s/8z2rgxvisni71y6/syncdesign2.pdf?dl=0
(image is worth a thousand words...)
Cheers!
Responder
