17257 Discussions
HOWTO: implement inferring ROM with registered output in m9k from HDL code?
In Quartus II web edition 9.1, I inserted a template:
module rom_test_inf # (parameter DATA_WIDTH=8, parameter ADDR_WIDTH=10) ( input addr, input clk, output reg q ); // Declare the ROM variable reg rom; initial begin $readmemb("rom_init_file.txt", rom); end always @ (posedge clk) begin q <= rom; end endmodule
the registers of output were NOT in m9k as I expected, but extra registers.
as attachments.
the last figure is what I want while it was implemented from megafunction.
but how from HDL code?
thanks
Your apparently refering to RTL view. As far as I know, all Quartus internal ROM/RAM needs at least one register (either implemented as address or output register). Because the template uses only one register level, Quartus can't but implement the register in the RAM/ROM block, whatever the RTL view tells. So if the ROM is infered at all, everything should be O.K.
