Hardware not detected
I am not able to program my altera fpga design board. I was able to do it earlier and I had tested many of my designs. However, very recently the board is not detected.
The board was detected and programmable in my colleagues computer. So I assume it's a driver issue.
However, the USB blaster driver cannot be removed nor updated in my computer due to some weird reason. The program never responds when such an action is performed. I even tried to download a new programmer from Altera and even restarted the computer, power-cycled the board but still the problem persists.
I have many versions of Altera Quartus2 installed in my computer, and hence I cannot remove all of them.
Can any one suggest a solution.
Thank you.
You mention that you have several versions of Quartus II installed, maybe you've run into the issue described here: http://www.altera.com/support/kdb/solutions/rd03062012_414.html
/J
--- Quote Start ---
/J
--- Quote End ---
The issue was fixed by removing altera programmer and signal tap installed separately and restarting the workstation. Thank you for the support.
