17255 Discussions
Segmentation Fault with Quartus installer (Ubuntu)
Hi there,
I'm trying to install Quartus II on my Ubuntu 14.04 64-bit machine. I need to compile and FPGA image from a script that doesn't support anything higher than 13.1, so I went and downloaded 13.0 and 13.1 SP1 along with my Cyclone IV device files and Modelsim.
Before all this I installed 14.0 without any problems, running the following command in bash:
cd ~/Downloads sudo chmod +x Quartus_blablabla.run ./Quartus_blablabla.run
Following the same procedure for the earlier versions only gives a message:
Segmentation fault (core dumped)
I've tried re-downloading it several times, and I've also tried to download the complete package of version 13, and running the install script gives the same error.
Any ideas?
One ideae : Have you tested your memory ?
The earlier versions would have almost certainly required 32-bit compatibility libraries to function...I'm not 100% sure that this is your issue, but it seems likely.
Cheers!
slacker
Hi and thanks for your replies.
A complete memory test revealed no errors.
As far as I understand (from the installation guide), 32-bit libraries are only required as a separate install if you run Red Hat or CentOS.
Cheers.
