17268 Discussions
Hello, I can't start a quartus (16.0) simulation, I entered the directory (screen attached), but I still have the error: "Executable ModelSim not found in .." (screen attached) what can I do? Thank you very much Nereo Turano
NTURA
NTURA
I solved the problem.
Nereo
RichardTanSY_Altera
I am glad the issue has been solved.
I believe the correct directory should be the example below:
C:\intelFPGA\18.1\modelsim_ase\win32aloem
Could you share your solution so others may refer? Thanks.
NTURA
I try to explain it in a simple pdf.
Nereo Turano
