17241 Discussions
Help using FIR II Compiler
Hello, I have a design in Quartus 9.1 that uses the FIR Compiler and want to move to Quartus 13 but FIR Compiler has been replaced by FIR II Compiler. FIR II is very different than FIR for example I don't see a setting to select the type of filter, low pass, high pass etc. Or, a setting to select the cutoff frequency, or a type of window. If anyone has experience with the FIR II Compiler I would like to know how to use it.
joe
