17267 Discussions
Help with Error Messages
Hi, this is my first time posting here. I just need some help figuring out how to correct my program. I'm new to VHDL. My assignment is to write VHDL coding to take information from ROM and output it to a video monitor. The 'ROM' is actually a mif picture stored in the same folder as the VHDL files. This picture is a 32 bit by 32 bit photo of an animal. The monitor is 640 x 480 pixels. The picture is to be written into part of the monitor. The rest of the monitor is to be black or just blank. This program is just to be simulated and not actually put on any hardware. The error messages are: Error (10500): VHDL syntax error at Homework7.vhd(28) near text "GENERIC"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at Homework7.vhd(33) near text ";"; expecting ":=", or "<="
Error (10500): VHDL syntax error at Homework7.vhd(34) near text ";"; expecting ":=", or "<=" The VHDL coding is attached. Thank you for your help, Mike
The generic clause is used set parameters of some component, like the number of bits of an input. For example:
entity incrementor is
generic(
WIDTH := 16
port(....
I modified version of the entity declaration may be:
ENTITY homework7 IS
PORT( clk, resetn : IN std_logic;
cs :IN std_logic;
address :IN std_logic_vector(9 DOWNTO 0);
q :OUT std_logic_vector(2 DOWNTO 0);
pixelout : OUT std_logic_vector(2 DOWNTO 0)
END homework7;
Thanks for your quick reply. The input "address" refers to a location in the picture.mif file. Also the output is supposed to be 3-bits and gives the pixel colors(I think). This whole part is to have only two inputs and one output. Won't setting it up the way you mention give it more inputs and outputs?
Thank you,
Mike
If I understand well address is an internal signal, the same with cs and q. So you are splitting your design in 2 aub-units. If so, this signals should not be visible in the entity declaration. Only appear below architecture/begin. Here you should instantiate 2 modules. One that output the pixelout signals ( and hsync and vsync ), and generates address. And the other module is the ram or rom storing the bitmap.
So, the signals address, cs, and q should be declared as in the following?
ENTITY homework7 IS
PORT (clk, resetn : IN std_logic;
pixelout : OUT std_logic_vector(2 DOWNTO 0));
END homework7;
ARCHITECTURE behavior OF homework7 IS
BEGIN
PROCESS
VARIABLE prow : INTEGER RANGE 0 TO 479 := 0;
VARIABLE pcol : INTEGER RANGE 0 TO 639 := 0;
VARIABLE count : INTEGER RANGE 0 TO 2 := 0;
VARIABLE address :IN std_logic_vector(9 DOWNTO 0);
VARIABLE cs :IN std_logic;
VARIABLE q :OUT std_logic_vector(2 DOWNTO 0);
VARIABLE paddress :std_logic_vector(9 DOWNTO 0):= "0000000000";
BEGIN
rom1: lpm_rom --megafunction to input data from picture
GENERIC MAP (lpm_width => 3, lpm_widthad => 10,
--3-bits per pixel
LPM_FILE => "picture.mif", --and 10-bit address
LPM_ADDRESS_CONTROL => "UNREGISTERED",
--for 1024 locations
LPM_OUTDATA => "UNREGISTERED")
PORT MAP(paddress => address, memenab => cs, q => q);
I do not know the correct way to use lpm_rom and read a particular address location. Currently I'm using 'paddress' and advancing that as in: paddress := paddress + 1;.
Thank you,
Mike
you cannot use an LPM rom inside a process. Components must be instantiated outside a process.
To do paddress := paddress + 1 you need the clock:
architecture..
variable paddress : unsigned(9 downto 0);
begin
process(resetn, clk)
begin
if(resetn = '0' ) then
paddress := "0000000000";
elsif(clk'event and clk ='1' ) then
end if;
end process;
Thank you guys for your quick replies. I'll have more questions this evening.
Mike
I'm not sure that I'm using 'lpm_rom' correctly. I was just checking the help section of Quartus and I found this:
FUNCTION lpm_rom(address[LPM_WIDTHAD-1..0],
inclock, outclock, memenab)
WITH (LPM_WIDTH, LPM_WIDTHAD, LPM_NUMWORDS, LPM_FILE,
LPM_ADDRESS_CONTROL, LPM_OUTDATA)
RETURNS (q[LPM_WIDTH-1..0]);
Or am I using it correctly in my code?
Thanks a lot,
Mike
My instructor said that, because this code is for the Cyclone II chip, which is synchronous, I need the inclock and outclock signals, but I can't find any information on how to use these in my code.
Thanks a lot,
Mike
