Help with VHDL VGA
Hi everyone
I'm just trying to use vga through de2-115 board
https://eewiki.net/pages/viewpage.action?pageid=15925278
I refer to this page and it works
but now I'm trying to make my own vga controller but it doesn't work
I think problem is on clock but it's just a guess
my monitor couldn't read signal from my code
I need your help
this is the top model
LIBRARY ieee;USE ieee.std_logic_1164.all; entity VGA is port( CLK :IN std_LOGIC; RED :OUT STD_LOGIC_VECTOR(7 DOWNTO 0); GREEN :OUT STD_LOGIC_VECTOR(7 DOWNTO 0); BLUE :OUT STD_LOGIC_VECTOR(7 DOWNTO 0); h_sync :OUT STD_LOGIC; v_sync :OUT STD_LOGIC; n_sync :OUT STD_LOGIC; n_blank :OUT STD_LOGIC; VGACLK :OUT STD_LOGIC ); END VGA; ARCHITECTURE AA OF VGA IS SIGNAL RESET : STD_LOGIC:='0'; component PLL is port ( clk_in_clk : in std_logic := 'X'; -- clk reset_reset : in std_logic := 'X'; -- reset clk_out_clk : out std_logic -- clk ); end component PLL; COMPONENT VGA_CONTROLLER IS PORT( pixel_clk : IN STD_LOGIC; --pixel clock at frequency of VGA mode being used reset_n : IN STD_LOGIC; --active low asycnchronous reset h_sync : OUT STD_LOGIC; --horiztonal sync pulse v_sync : OUT STD_LOGIC; --vertical sync pulse disp_ena : OUT STD_LOGIC; --display enable ('1' = display time, '0' = blanking time) column : OUT INTEGER; --horizontal pixel coordinate row : OUT INTEGER; --vertical pixel coordinate n_blank : OUT STD_LOGIC; --direct blacking output to DAC n_sync : OUT STD_LOGIC); --sync-on-green output to DAC END COMPONENT; COMPONENT HW_IMAGE_GENERATOR IS PORT( disp_ena : IN STD_LOGIC; --display enable ('1' = display time, '0' = blanking time) COLUmn : IN INTEGER; --row pixel coordinate ROW : IN INTEGER; red : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --red magnitude output to DAC green : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --green magnitude output to DAC blue : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0')); --blue magnitude output to DAC END COMPONENT; SIGNAL disp_ena : STD_LOGIC; SIGNAL row : INTEGER; SIGNAL column : INTEGER; SIGNAL reset_n : STD_LOGIC; SIGNAL PIXel_clk : STD_LOGIC; begin VGACLK<=PIXel_clk; U1: PLL PORT MAP ( CLK, reset_N, PIXel_clk); u2: vga_CONTROLLER port map (pixel_clk, reset_N, h_sync, v_sync, disp_ena, COLUmn, ROW, n_blank, n_sync); u3: hw_IMAGE_GENERATOR port map (disp_ena,COLUmn, ROW, RED,GREEN,BLUE); end AA;
and other codes
LIBRARY ieee;USE ieee.std_logic_1164.all; ENTITY hw_image_generator IS GENERIC( pixels_y : INTEGER := 478; --row that first color will persist until pixels_x : INTEGER := 600); --column that first color will persist until PORT( disp_ena : IN STD_LOGIC; --display enable ('1' = display time, '0' = blanking time) row : IN INTEGER; --row pixel coordinate column : IN INTEGER; red : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --red magnitude output to DAC green : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --green magnitude output to DAC blue : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0')); --blue magnitude output to DAC END hw_image_generator; ARCHITECTURE behavior OF hw_image_generator IS BEGIN PROCESS(disp_ena, row, column) BEGIN IF(disp_ena = '1') THEN --display time IF(row < pixels_y AND column < pixels_x) THEN red <= (OTHERS => '0'); green <= (OTHERS => '0'); blue <= (OTHERS => '1'); ELSE red <= (OTHERS => '1'); green <= (OTHERS => '1'); blue <= (OTHERS => '0'); END IF; ELSE --blanking time red <= (OTHERS => '0'); green <= (OTHERS => '0'); blue <= (OTHERS => '0'); END IF; END PROCESS; END behavior;
LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY vga_controller IS GENERIC( h_pulse : INTEGER := 208; --horiztonal sync pulse width in pixels h_bp : INTEGER := 336; --horiztonal back porch width in pixels h_pixels : INTEGER := 1920; --horiztonal display width in pixels h_fp : INTEGER := 128; --horiztonal front porch width in pixels h_pol : STD_LOGIC := '0'; --horizontal sync pulse polarity (1 = positive, 0 = negative) v_pulse : INTEGER := 3; --vertical sync pulse width in rows v_bp : INTEGER := 38; --vertical back porch width in rows v_pixels : INTEGER := 1200; --vertical display width in rows v_fp : INTEGER := 1; --vertical front porch width in rows v_pol : STD_LOGIC := '1'); --vertical sync pulse polarity (1 = positive, 0 = negative) PORT( pixel_clk : IN STD_LOGIC; --pixel clock at frequency of VGA mode being used reset_n : IN STD_LOGIC; --active low asycnchronous reset h_sync : OUT STD_LOGIC; --horiztonal sync pulse v_sync : OUT STD_LOGIC; --vertical sync pulse disp_ena : OUT STD_LOGIC; --display enable ('1' = display time, '0' = blanking time) column : OUT INTEGER; --horizontal pixel coordinate row : OUT INTEGER; --vertical pixel coordinate n_blank : OUT STD_LOGIC; --direct blacking output to DAC n_sync : OUT STD_LOGIC); --sync-on-green output to DAC END vga_controller; ARCHITECTURE behavior OF vga_controller IS CONSTANT h_period : INTEGER := h_pulse + h_bp + h_pixels + h_fp; --total number of pixel clocks in a row CONSTANT v_period : INTEGER := v_pulse + v_bp + v_pixels + v_fp; --total number of rows in column BEGIN n_blank <= '1'; --no direct blanking n_sync <= '0'; --no sync on green PROCESS(pixel_clk, reset_n) VARIABLE h_count : INTEGER RANGE 0 TO h_period - 1 := 0; --horizontal counter (counts the columns) VARIABLE v_count : INTEGER RANGE 0 TO v_period - 1 := 0; --vertical counter (counts the rows) BEGIN IF(reset_n = '0') THEN --reset asserted h_count := 0; --reset horizontal counter v_count := 0; --reset vertical counter h_sync <= NOT h_pol; --deassert horizontal sync v_sync <= NOT v_pol; --deassert vertical sync disp_ena <= '0'; --disable display column <= 0; --reset column pixel coordinate row <= 0; --reset row pixel coordinate ELSIF(pixel_clk'EVENT AND pixel_clk = '1') THEN --counters IF(h_count < h_period - 1) THEN --horizontal counter (pixels) h_count := h_count + 1; ELSE h_count := 0; IF(v_count < v_period - 1) THEN --veritcal counter (rows) v_count := v_count + 1; ELSE v_count := 0; END IF; END IF; --horizontal sync signal IF(h_count < h_pixels + h_fp OR h_count >= h_pixels + h_fp + h_pulse) THEN h_sync <= NOT h_pol; --deassert horiztonal sync pulse ELSE h_sync <= h_pol; --assert horiztonal sync pulse END IF; --vertical sync signal IF(v_count < v_pixels + v_fp OR v_count >= v_pixels + v_fp + v_pulse) THEN v_sync <= NOT v_pol; --deassert vertical sync pulse ELSE v_sync <= v_pol; --assert vertical sync pulse END IF; --set pixel coordinates IF(h_count < h_pixels) THEN --horiztonal display time column <= h_count; --set horiztonal pixel coordinate END IF; IF(v_count < v_pixels) THEN --vertical display time row <= v_count; --set vertical pixel coordinate END IF; --set display enable output IF(h_count < h_pixels AND v_count < v_pixels) THEN --display time disp_ena <= '1'; --enable display ELSE --blanking time disp_ena <= '0'; --disable display END IF; END IF; END PROCESS; END behavior;
Have you written a testbench for this? then you can verify the timing of your signals.
I've never made testbench before. Would you mind if I ask you to explain how to do that?
there are many tutorials out there that go through the testbench process that would explain it better than a forum post. Some even provided by altera.
