17255 Discussions
Help with a simple RAM code - VHDL
Hello everyone,
So I have been trying to write a simple VHDL code for a RAM with the following conditions, no success yet. Can anyone please help me with a code?.
1. Say I need a 2KB RAM with 1024 address locations and each location will be filled with 16 bit data.
2. My first 4 memoy locations should have the value 1122, 3344, 5566, 7788, 9988, and the rest should have values from 0 to 1019 respectively.
I am struggling with the part where I need the first 4 locations to be a specific value, and the rest to be the counter values from 0 to 1019. I don't know how to write that in VHDL.
Please help me with a code, . Will be highly appreciated, thanks.
Kind Regards,
Manoj
--- Quote Start ---
Hello everyone,
Kind Regards,
Manoj
--- Quote End ---
I will just instantiate it with mif (with freedom from hdl inference)
fid = fopen('filename.mif','w'); fprintf(fid,'--MIF data generated by MATLAB\n'); fprintf(fid,'--Date: %s \n\n', date); fprintf(fid,'WIDTH=16;\n'); fprintf(fid,'DEPTH=1024;\n'); fprintf(fid,'ADDRESS_RADIX=UNS;\n'); fprintf(fid,'DATA_RADIX=DEC;\n'); fprintf(fid,'CONTENT BEGIN\n'); fprintf(fid,'0 : 1122;\n'); fprintf(fid,'1 : 3344;\n'); fprintf(fid,'2 : 5566;\n'); fprintf(fid,'3 : 7788;\n'); fprintf(fid,'4 : 9988;\n'); for i = 5:1023 fprintf(fid,'%i : %i;\n',i,i-5); end fprintf(fid,'END;'); fclose(fid);
Thank you. I see that you have used filename.mif, is that from MATLAB?
Is there a way to write the same program, say using a basic simulator like ModelSIM?
Manoj
--- Quote Start ---
Manoj
--- Quote End ---
Yes that is matlab geneartion
I believe you can write text file in Modelsim in same way. run a counter 0_1023
set values for signal temp as your values depending on counter value then write text file out.
I attach the file if it helps (change extension back to .mif)
